Ana içeriğe geç
HP Pavilion 15-au123cl CD Drive Replacement
Mohammad Gardezi
Mohammad Gardezi ve başka bir katkıda bulunan
En son December 28, 2017 tarihinde güncellendi
15 - 20 dakika
Orta
By following this guide, you will be able to replace the CD Drive. The drive is probably the easiest part to replace on the laptop.
Neye ihtiyacın var
Aletler
  1. HP Pavilion 15-au123cl CD Drive Replacement, Battery: adım 1, 1 resimden 1.
    • Make sure the laptop is off and unplugged before starting.
    • Using the plastic opening tool, remove the top rubber feet on the back panel as it hides one of the screws we will be removing.
  2. HP Pavilion 15-au123cl CD Drive Replacement: adım 2, 2 resimden 1. HP Pavilion 15-au123cl CD Drive Replacement: adım 2, 2 resimden 2.
    • Using a PH0 screwdriver, unscrew the ten 4.4mm Phillips head screws located on the back panel.
  3. HP Pavilion 15-au123cl CD Drive Replacement: adım 3, 2 resimden 1. HP Pavilion 15-au123cl CD Drive Replacement: adım 3, 2 resimden 2.
    • Using the plastic opening tool, remove the back cover of the laptop.
    • It is recommended that you start with a corner and run the tool throughout the edges of the cover.
    • Be sure not to bend the cover by applying too much force.
  4. HP Pavilion 15-au123cl CD Drive Replacement: adım 4, 2 resimden 1. HP Pavilion 15-au123cl CD Drive Replacement: adım 4, 2 resimden 2.
    • Using a PH0 screwdriver, unscrew the two 3.8mm PH0 Phillips head screws that hold the battery in place.
  5. HP Pavilion 15-au123cl CD Drive Replacement: adım 5, 3 resimden 1. HP Pavilion 15-au123cl CD Drive Replacement: adım 5, 3 resimden 2. HP Pavilion 15-au123cl CD Drive Replacement: adım 5, 3 resimden 3.
    • Carefully disconnect the cable connecting the top of the battery and remove the battery.
  6. HP Pavilion 15-au123cl CD Drive Replacement, CD Drive: adım 6, 1 resimden 1.
    • The CD Drive is located at the bottom right area of the motherboard.
  7. HP Pavilion 15-au123cl CD Drive Replacement: adım 7, 2 resimden 1. HP Pavilion 15-au123cl CD Drive Replacement: adım 7, 2 resimden 2.
    • Disconnect the CD drive from the motherboard connector on the left.
Sonuç
Mohammad Gardezi
1.420 İtibar
6 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S13-G3, Cagle Fall 2017 USF Tampa, Team S13-G3, Cagle Fall 2017 üyesi
USFT-CAGLE-F17S13G3
2 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 20
Her zaman: 631
