Ana içeriğe geç
HP Pavilion 15-au123cl Hard Drive Replacement
Neye ihtiyacın var
    1. HP Pavilion 15-au123cl Hard Drive Replacement, Battery: adım 1, 1 resimden 1.
      • Make sure the laptop is off and unplugged before starting.
      • Using the plastic opening tool, remove the top rubber feet on the back panel as it hides one of the screws we will be removing.
      FixBot'a Sor
      Yorum Ekle
    2. HP Pavilion 15-au123cl Hard Drive Replacement: adım 2, 2 resimden 1. HP Pavilion 15-au123cl Hard Drive Replacement: adım 2, 2 resimden 2.
      • Using a PH0 screwdriver, unscrew the ten 4.4mm Phillips head screws located on the back panel.
      FixBot'a Sor
      Yorum Ekle
    3. HP Pavilion 15-au123cl Hard Drive Replacement: adım 3, 2 resimden 1. HP Pavilion 15-au123cl Hard Drive Replacement: adım 3, 2 resimden 2.
      • Using the plastic opening tool, remove the back cover of the laptop.
      • It is recommended that you start with a corner and run the tool throughout the edges of the cover.
      • Be sure not to bend the cover by applying too much force.
      FixBot'a Sor
      Yorum Ekle
    4. HP Pavilion 15-au123cl Hard Drive Replacement: adım 4, 2 resimden 1. HP Pavilion 15-au123cl Hard Drive Replacement: adım 4, 2 resimden 2.
      • Using a PH0 screwdriver, unscrew the two 3.8mm PH0 Phillips head screws that hold the battery in place.
      FixBot'a Sor
      Yorum Ekle
    5. HP Pavilion 15-au123cl Hard Drive Replacement: adım 5, 3 resimden 1. HP Pavilion 15-au123cl Hard Drive Replacement: adım 5, 3 resimden 2. HP Pavilion 15-au123cl Hard Drive Replacement: adım 5, 3 resimden 3.
      • Carefully disconnect the cable connecting the top of the battery and remove the battery.
      FixBot'a Sor
      Yorum Ekle
    1. HP Pavilion 15-au123cl Hard Drive Replacement, Hard Drive: adım 6, 3 resimden 1. HP Pavilion 15-au123cl Hard Drive Replacement, Hard Drive: adım 6, 3 resimden 2. HP Pavilion 15-au123cl Hard Drive Replacement, Hard Drive: adım 6, 3 resimden 3.
      • The hard drive is located at the lower left area of the motherboard.
      • Using the spudger, lift the white latch holding the hard drive cable in place.
      FixBot'a Sor
      Yorum Ekle
    2. HP Pavilion 15-au123cl Hard Drive Replacement: adım 7, 1 resimden 1.
      • Using the opening tool, lift the hard drive out of the motherboard.
      FixBot'a Sor
      Yorum Ekle
    3. HP Pavilion 15-au123cl Hard Drive Replacement: adım 8, 2 resimden 1. HP Pavilion 15-au123cl Hard Drive Replacement: adım 8, 2 resimden 2.
      • Remove the hard drive cable from the hard drive.
      FixBot'a Sor
      Yorum Ekle
    4. HP Pavilion 15-au123cl Hard Drive Replacement: adım 9, 2 resimden 1. HP Pavilion 15-au123cl Hard Drive Replacement: adım 9, 2 resimden 2.
      • Pull off the plastic wedges on both sides of the hard drive.
      FixBot'a Sor
      Yorum Ekle
Sonuç
10 farklı kişi bu kılavuzu tamamladı.
Mohammad Gardezi
1.420 İtibar
6 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S13-G3, Cagle Fall 2017 USF Tampa, Team S13-G3, Cagle Fall 2017 üyesi
USFT-CAGLE-F17S13G3
2 Üyeler
72 adet Kılavuz yazıldı
1Rehber Yorum
The latch on mine was black, and the socket on the m/b was white. Guess who ruined his m/b following these instructions?
TJ Fitzgerald - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 28
Son 30 gün: 65
Her zaman: 7,850
