Ana içeriğe geç
HP Pavilion 15-au123cl Hard Drive Replacement
Mohammad Gardezi
Mohammad Gardezi ve 2 diğer katkıda bulunanlar
En son November 15, 2022 tarihinde güncellendi
15 - 20 dakika
Orta
Öne Çıkan Öğrenci Kılavuzu
If you have noticed that your computer is no longer booting up and you have come to the conclusion that the hard drive is the problem, this guide will walk you through the sets to replace the hard drive. You will first remove the battery and then the hard drive. Using the tools suggested, you should have no problem removing the hard drive.
Neye ihtiyacın var
Tamir Setleri
Bu kitler, bu kılavuzu tamamlamak için gereken tüm parçaları ve araçları içerir.
Parçalar
Aletler
Daha fazlasını göster…
  1. HP Pavilion 15-au123cl Hard Drive Replacement, Battery: adım 1, 1 resimden 1.
    • Make sure the laptop is off and unplugged before starting.
    • Using the plastic opening tool, remove the top rubber feet on the back panel as it hides one of the screws we will be removing.
  2. HP Pavilion 15-au123cl Hard Drive Replacement: adım 2, 2 resimden 1. HP Pavilion 15-au123cl Hard Drive Replacement: adım 2, 2 resimden 2.
    • Using a PH0 screwdriver, unscrew the ten 4.4mm Phillips head screws located on the back panel.
    Correction. Top two screen pivot screws are bigger than the 8, 4mm.
    Mitchell Culp II - Yanıt
  3. HP Pavilion 15-au123cl Hard Drive Replacement: adım 3, 2 resimden 1. HP Pavilion 15-au123cl Hard Drive Replacement: adım 3, 2 resimden 2.
    • Using the plastic opening tool, remove the back cover of the laptop.
    • It is recommended that you start with a corner and run the tool throughout the edges of the cover.
    • Be sure not to bend the cover by applying too much force.
    What? I think you have have neglected to mention the DVD drawer. I believe it needs to be pulled out after removing the center screw and before removing the cover.
    Dan Enslow - Yanıt
    Yes, best to remove the drawer as recommended. Also there are 3 screws holding the battery, not 2.
    Lastly, pay careful attention to the orientation photo when removing the back.
    I did not have the plastic tool but used a small Teflon type kitchen spatula and it did the trick. Do not use a metal screw driver or other such tool.
    Edward Yandek - Yanıt
  4. HP Pavilion 15-au123cl Hard Drive Replacement: adım 4, 2 resimden 1. HP Pavilion 15-au123cl Hard Drive Replacement: adım 4, 2 resimden 2.
    • Using a PH0 screwdriver, unscrew the two 3.8mm PH0 Phillips head screws that hold the battery in place.
    there is a third screw on bottom left of battery (in picture above)
    Paul Behrman - Yanıt
  5. HP Pavilion 15-au123cl Hard Drive Replacement: adım 5, 3 resimden 1. HP Pavilion 15-au123cl Hard Drive Replacement: adım 5, 3 resimden 2. HP Pavilion 15-au123cl Hard Drive Replacement: adım 5, 3 resimden 3.
    • Carefully disconnect the cable connecting the top of the battery and remove the battery.
  6. HP Pavilion 15-au123cl Hard Drive Replacement, Hard Drive: adım 6, 3 resimden 1. HP Pavilion 15-au123cl Hard Drive Replacement, Hard Drive: adım 6, 3 resimden 2. HP Pavilion 15-au123cl Hard Drive Replacement, Hard Drive: adım 6, 3 resimden 3.
    • The hard drive is located at the lower left area of the motherboard.
    • Using the spudger, lift the white latch holding the hard drive cable in place.
  7. HP Pavilion 15-au123cl Hard Drive Replacement: adım 7, 1 resimden 1.
    • Using the opening tool, lift the hard drive out of the motherboard.
  8. HP Pavilion 15-au123cl Hard Drive Replacement: adım 8, 2 resimden 1. HP Pavilion 15-au123cl Hard Drive Replacement: adım 8, 2 resimden 2.
    • Remove the hard drive cable from the hard drive.
  9. HP Pavilion 15-au123cl Hard Drive Replacement: adım 9, 2 resimden 1. HP Pavilion 15-au123cl Hard Drive Replacement: adım 9, 2 resimden 2.
    • Pull off the plastic wedges on both sides of the hard drive.
Sonuç
10 farklı kişi bu kılavuzu tamamladı.
Mohammad Gardezi
1.420 İtibar
6 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S13-G3, Cagle Fall 2017 USF Tampa, Team S13-G3, Cagle Fall 2017 üyesi
USFT-CAGLE-F17S13G3
2 Üyeler
Bir Yorum
The latch on mine was black, and the socket on the m/b was white. Guess who ruined his m/b following these instructions?
TJ Fitzgerald - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 18
Son 30 gün: 79
Her zaman: 7,000
