Ana içeriğe geç
HP Pavilion 15-bk020wm Battery Replacement
Neye ihtiyacın var
  1. HP Pavilion 15-bk020wm Battery Replacement, Keyboard Cover: adım 1, 2 resimden 1. HP Pavilion 15-bk020wm Battery Replacement, Keyboard Cover: adım 1, 2 resimden 2.
    • Before you begin, turn the laptop off and unplug it from the power source.
    • Remove the 4 computer feet. (Our device didn't have these; they can be taken off with a plastic spudger.)
    • Remove the two screw cover strips.
    • Remove the two screw cover plugs.
    • Unscrew all 12 screws (size: Phillips M2.5×7.0 ) from the bottom of the computer.
  2. HP Pavilion 15-bk020wm Battery Replacement: adım 2, 3 resimden 1. HP Pavilion 15-bk020wm Battery Replacement: adım 2, 3 resimden 2. HP Pavilion 15-bk020wm Battery Replacement: adım 2, 3 resimden 3.
    • Turn the computer over to the front.
    • Open the laptop.
    • Use a plastic pry tool to pry up the keyboard cover near the hinge on both the right and left side, and work your way towards the touchpad.
  3. HP Pavilion 15-bk020wm Battery Replacement: adım 3, 1 resimden 1.
    • Tilt the keyboard cover up slightly.
    • Do not fully remove the keyboard, as it is still attached to the laptop by some cables.
  4. HP Pavilion 15-bk020wm Battery Replacement, Battery: adım 4, 2 resimden 1. HP Pavilion 15-bk020wm Battery Replacement, Battery: adım 4, 2 resimden 2.
    • Detach the blue ZIF cable from the bottom of the laptop.
    • Use a plastic opening tool to flip up the two ZIF cables connecting the battery to the motherboard.
  5. HP Pavilion 15-bk020wm Battery Replacement: adım 5, 1 resimden 1.
    • Remove the four Phillips M2.5x4.4 screws using the Phillips 00 located along the perimeter of the battery.
  6. HP Pavilion 15-bk020wm Battery Replacement: adım 6, 1 resimden 1.
    • Lift the damaged battery from the laptop.
    • Insert the new battery.
Sonuç
8 farklı kişi bu kılavuzu tamamladı.
2 Yorum
Hidden bolts are tricky to understand at first.
Riben Deguhur - Yanıt
can i still use my laptop without the battery (the same type of battery shown on those picture) and directly plugged in?? I've been worried since it's just stuck on a very low percentage
Shouko kazumi - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 12
Son 7 gün: 66
Son 30 gün: 299
Her zaman: 69,230
