Giriş
Use this guide to replace the bottom cover in a HP Pavilion 15-cc561st (product number 1KU29UA).
The bottom cover protects the computer's components and has rubber feet to prevent the laptop from slipping. The air vents are also located on the bottom cover and can be cleaned to improve airflow and performance.
Removing the bottom cover is a required step for replacing every other component.
Shut down the laptop, disconnect all external devices, and unplug the AC adapter before beginning.
Neye ihtiyacın var
Use a Phillips #0 screwdriver to remove five screws from the bottom cover:
Two 5.6 mm screws
Three 5.8 mm screws
