Giriş
This guide shows you how to replace the built-in LCD display screen of the HP Pavilion 15-cc561st. This can fix issues such as broken screen, discolored screen, flickering screen, burnt-out pixels, etc.
Neye ihtiyacın var
Bu adımda kullanılan alet:Magnetic Project Mat$19.95
Use a Phillips #0 screwdriver to remove five screws from the bottom cover:
Two 5.6 mm screws
Three 5.8 mm screws
Use a Phillips #0 screwdriver to remove the five 5.7 mm screws that secure the battery.
Disconnect the WLAN antenna cables from the terminals on the WLAN module:
Cable labeled "1/AUX" which connects to the "Aux" terminal
Cable labeled "2/MAIN" which connects to the "Main" terminal
To remove the ZIF ribbon, lift the plastic tab and gently pull the ZIF ribbon away from the connector.
