Giriş
WARNING: The computer should be off (no power running), unplugged and the battery must be removed to prevent electrical shock.
This guide will help you replace the keyboard of the HP Pavilion 15-n210dx if you are having difficulties with it. Difficulties can include numerous keys missing, broken key caps, or unresponsive keys.
The keyboard is made to endure millions of strokes. Sometimes a combination of keys need to be pressed to execute an action. When keys start to stop working, replacing the keyboard as a whole is recommended. If only a couple keys need to be replaced, refer to the keyboard section of the troubleshooting page.
Only a metal spudger is needed for this replacement.
Neye ihtiyacın var
Turn over the laptop and remove the single screw using a Tri-point Y0 screwdriver.
