Ana içeriğe geç
HP Pavilion 15-p Palmrest Replacement
Neye ihtiyacın var
  1. HP Pavilion 15-p Palmrest Replacement, Prepare the laptop: adım 1, 3 resimden 1. HP Pavilion 15-p Palmrest Replacement, Prepare the laptop: adım 1, 3 resimden 2. HP Pavilion 15-p Palmrest Replacement, Prepare the laptop: adım 1, 3 resimden 3.
    • Shut the laptop down until it is hibernated or shut off. Do not remove power until both lights turn off.
  2. HP Pavilion 15-p Palmrest Replacement, Unlock the  battery: adım 2, 3 resimden 1. HP Pavilion 15-p Palmrest Replacement, Unlock the  battery: adım 2, 3 resimden 2. HP Pavilion 15-p Palmrest Replacement, Unlock the  battery: adım 2, 3 resimden 3.
    • Once the computer is off, remove the battery. Switch the locking tab to the unlocked position.
  3. HP Pavilion 15-p Palmrest Replacement, Remove the battery: adım 3, 2 resimden 1. HP Pavilion 15-p Palmrest Replacement, Remove the battery: adım 3, 2 resimden 2.
    • Remove the battery. Pull the battery forward and remove it from the laptop.
  4. HP Pavilion 15-p Palmrest Replacement, Remove the optical drive: adım 4, 3 resimden 1. HP Pavilion 15-p Palmrest Replacement, Remove the optical drive: adım 4, 3 resimden 2. HP Pavilion 15-p Palmrest Replacement, Remove the optical drive: adım 4, 3 resimden 3.
    • EET owners: Your kit has this bit. No purchase needed.
    • Remove the screw that holds the optical drive in. To do this, use a Phillips #0 screwdriver. Slide the optical drive out once the screw is removed.
    No puedo quitar la unidad
    César - Yanıt
    Try using a Philips #00 and see if that works. Not the first time this occurred.
    Spanish translation:
    Intente usar un Philips #00 y vea si funciona. No es la primera vez que esto ocurre.
    Nick -
  5. HP Pavilion 15-p Palmrest Replacement, Remove the screws under the optical drive: adım 5, 1 resimden 1.
    • The system used in the guide only came with one screw. If yours came with three, sort accordingly.
    • With the palmrest screws removed, remove the screws under the optical drive. Use a Phillips #000 screwdriver.
    If I'm having troublds removing this screw what should I do? Using a Phillips #00
    mjsbak - Yanıt
    Try a Phillps #000 screwdriver. It worked for me with a #00, but #000 is a better fit when I revisited this.
    Nick -
    Mine has been worn out due to excessive use. What should I use to remove this screw?
    Ahmed Khan - Yanıt
    It's too difficult
    César - Yanıt
  6. HP Pavilion 15-p Palmrest Replacement, Remove the bottom screws: adım 6, 1 resimden 1.
    • Once the battery and optical drive are removed, remove the 11 Phillips #0 screws that secure the palmrest.
    • This screw is hidden by a sticker. If lost/damaged, it is cosmetic.
    • Not found on all models. On some models, there are screws in this area. If you see screws here, they must be removed.
    Caution: There are two additional screws on some models in the battery pack area on the far left and right of single screw shown in the picture above. Make sure to remove those screws as they are also securing the back of the palm rest to the computer.
    David May - Yanıt
    Good catch. I made the assumption all machines in the P series come apart the same way since multiple chassis in the same line are rare. What model machine do you have?
    Now that I’ve looked at my picture, I think I know what you’re talking about. I think you’re taking about the square areas that were never used on my machine?
    Nick -
    I added a marker to account for this. I meant to do it sooner, but it slipped past me. Let me know if I put the markers in the wrong location. I have not seen one of these, so I don’t know with 100% certainty.
    Nick -
  7. HP Pavilion 15-p Palmrest Replacement, Remove the hinge caps: adım 7, 3 resimden 1. HP Pavilion 15-p Palmrest Replacement, Remove the hinge caps: adım 7, 3 resimden 2. HP Pavilion 15-p Palmrest Replacement, Remove the hinge caps: adım 7, 3 resimden 3.
    • If you choose to reuse the original pads, stick them to the hinge caps to preserve the adhesive.
    • Remove the hinge caps. To do this, remove the rubber pads. Use a Phillps #0 screwdriver.
    • Remove the screws under the hinge caps. To do this, use a Phillps #0 screwdriver.
  8. HP Pavilion 15-p Palmrest Replacement, Unsnap the palmrest: adım 8, 3 resimden 1. HP Pavilion 15-p Palmrest Replacement, Unsnap the palmrest: adım 8, 3 resimden 2. HP Pavilion 15-p Palmrest Replacement, Unsnap the palmrest: adım 8, 3 resimden 3.
    • EET owners: Your kit has the needed picks. No purchase needed.
    • Do not fully remove the palmrest - the power button is still connected to the motherboard.
    • If you are having trouble removing the palmrest, try using a guitar pick.
    • Run a plastic tool around all 3 sides of the palmrest. Once they are loose, disconnect the keyboard and trackpad. Flip the black plastic tabs on the connectors up and disconnect the cables.
    • Once the keyboard and trackpad are disconnected, the palmrest can be lifted up. In some cases, further prying may be needed.
    >Step 8 Remove the palmrest
    >Do not remove the palmrest.
    lolwut
    Toynbee Idea - Yanıt
    Not sure if you’re being serious or sarcastic. If you’re serious, it says it in the line you quoted that from why it has to wait.
    Nick -
    This is very difficult to remove. I managed to get the hard drive removed without removing it completely. The corners would not come loose and I didn’t want to risk cracking the palmrest.
    Hollow Hills Ranch & Homestead - Yanıt
    The trick I’ve used on this HP chaissis is I will go over the back tabs with more attention then the rest, and then go over it again just to be sure.
    The alternative is to buy anything else that isn’t awful to service, but sadly if you own it you can’t do much about it.
    Nick -
    NOTE! The ONLY cloning tool that created bootable (HP Pavillion) clone was DiskGenius software's "OS Migrate" button. I spent tens of hours with other software only to experience BSOD's (Blue screen of death) during the boot-up. Windows 8.1 install DVD's standard Command line boot repair tools could not fix the issues that other cloning tools created. The cloning tools tried were Acronis, Clonezilla, Macrium Reflect but they produced unbootable laptop. DiskGenius is not the cutest software but I wish I had it in the beginning. My two cents..
    - Teemu Parkkunen
    Teemu Parkkunen - Yanıt
    EDIT: On my previous comment I mentioned that DiskGenius was the the only working option for this Windows 8.1 Pavillion cloning. Now it turned out that the target SSD was faulty. There was bad sector on boot area. This may have contributed to the fact that cloning was a hit or miss process. So feel free to try any cloning sofware.
    Teemu Parkkunen -
  9. HP Pavilion 15-p Palmrest Replacement, Disconnect the power button: adım 9, 3 resimden 1. HP Pavilion 15-p Palmrest Replacement, Disconnect the power button: adım 9, 3 resimden 2. HP Pavilion 15-p Palmrest Replacement, Disconnect the power button: adım 9, 3 resimden 3.
    • With the keyboard and trackpad disconnected, disconnect the power button. Flip the black tab up and remove the palmrest.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Nick
93.806 İtibar
59 adet Kılavuz yazıldı
Ekip
Master Techs Master Techs üyesi
Community
327 Üyeler
1.672 adet Kılavuz yazıldı
6Kılavuz Yorumları
My power button is bad and my mouse track stopped working. I couldn't find a replacement for it. What can I do?
Trevor Gilbert - Yanıt
hi where can i source a replacement palm rest assembly for my hp pavilion 15 2015. its the same as the first laptop picture
Oche Ejiga - Yanıt
You have the US ENG keyboard most likely. I posted the parts list as new steps (762529-001 or 762530-001). Verify it based on the part number sticker to be absolutely sure though but that is likely a match.
Nick -
Hi my hinge broke off and so was some of my speaker. Plus, its making my screen close on its own and I can't keep it still. :( Where can I get a replacement for the palmrest, keyboard, and touchpad? My model for my hp pavillion laptop is: 3C310UA#ABA
thecrowrules1982 - Yanıt
Parts laptop, or a junk laptop with a bad motherboard (BIOS lock or dead power). The bare part tends to be ~$150+ if it's available and will only get worse as they become hard to find.
Nick -
Hola, necesito ayuda con mi laptop y no se a quien dirigirme. Me podéis echar una mano a montarlo, que lo he desmontado y ahora estoy en un lio.
Daniel Slavchev Slavchev - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 11
Son 30 gün: 73
Her zaman: 6,976
