Ana içeriğe geç
HP Pavilion 17-e146us Charger Port Replacement
Neye ihtiyacın var
  1. HP Pavilion 17-e146us Charger Port Replacement, Battery: adım 1, 1 resimden 1.
    • Turn the device over.
  2. HP Pavilion 17-e146us Charger Port Replacement: adım 2, 2 resimden 1. HP Pavilion 17-e146us Charger Port Replacement: adım 2, 2 resimden 2.
    • Move the battery lock switch to the right to unlock. The battery release button will unlock the battery from the computer.
    • The battery release button is located above the the battery.
  3. HP Pavilion 17-e146us Charger Port Replacement: adım 3, 1 resimden 1.
    • The battery will unlock from the computer.
    • Remove the unlocked battery from the computer.
  4. HP Pavilion 17-e146us Charger Port Replacement, Keyboard: adım 4, 3 resimden 1. HP Pavilion 17-e146us Charger Port Replacement, Keyboard: adım 4, 3 resimden 2. HP Pavilion 17-e146us Charger Port Replacement, Keyboard: adım 4, 3 resimden 3.
    • Remove the 6.25 mm screw in the left-lower hand corner of the battery port using a Phillips head screw driver.
  5. HP Pavilion 17-e146us Charger Port Replacement: adım 5, 1 resimden 1.
    • Remove the HP protect smart ventilation case.
    • The smart ventilation is a part of the back cover of the device
  6. HP Pavilion 17-e146us Charger Port Replacement: adım 6, 1 resimden 1.
    • Remove seven 6.5 mm screws using a Phillips #0 screwdriver.
    • Remove four 3.0 mm screws located in the charger port using a Phillips #0 screwdriver.
  7. HP Pavilion 17-e146us Charger Port Replacement: adım 7, 2 resimden 1. HP Pavilion 17-e146us Charger Port Replacement: adım 7, 2 resimden 2.
    • Pull and remove the disk drive.
    • The disk drive is located on the left side of the device when it is turned over.
    • Remove two 3.00 mm screws on the inside of the disk drive using a Phillips screwdriver.
  8. HP Pavilion 17-e146us Charger Port Replacement: adım 8, 1 resimden 1.
    • Apply firm pressure inside the release port using a narrow tool such as a screw driver or tweezers.
    • The release port releases the keyboard.
  9. HP Pavilion 17-e146us Charger Port Replacement: adım 9, 1 resimden 1.
    • Flip device over so that the cover is facing towards you
  10. HP Pavilion 17-e146us Charger Port Replacement: adım 10, 3 resimden 1. HP Pavilion 17-e146us Charger Port Replacement: adım 10, 3 resimden 2. HP Pavilion 17-e146us Charger Port Replacement: adım 10, 3 resimden 3.
    • Open device. The keyboard should be separate from the inside panel.
    • If the keyboard does not automatically pop out, use a spudger or opening tool along the edge of the front panel and the keyboard to pop the keyboard out.
    • Detach the keyboard's cable connector from the motherboard.
  11. HP Pavilion 17-e146us Charger Port Replacement, Motherboard: adım 11, 1 resimden 1.
    • Remove three 6.5 mm Phillips screws located underneath the keyboard using a Phillips #0 screwdriver.
  12. HP Pavilion 17-e146us Charger Port Replacement: adım 12, 1 resimden 1.
    • Place wedge tool in-between the front panel and the cover underneath the keyboard
    • Use wedge tool to pop the two covers apart.
    • This may require some force.
  13. HP Pavilion 17-e146us Charger Port Replacement: adım 13, 2 resimden 1. HP Pavilion 17-e146us Charger Port Replacement: adım 13, 2 resimden 2.
    • Remove the motherboard using your hands
    • The motherboard is large green portion located inside the device
  14. HP Pavilion 17-e146us Charger Port Replacement, Charger Port: adım 14, 2 resimden 1. HP Pavilion 17-e146us Charger Port Replacement, Charger Port: adım 14, 2 resimden 2.
    • The charging port is attached to the motherboard and is on the right side of the device if it is facing you.
    • Remove the charging port from motherboard by hand.
    • Be careful not to break the motherboard during removal
Sonuç
Emma Neumann
629 İtibar
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 17
Her zaman: 858
