Ana içeriğe geç
HP Pavilion 17-e146us Screen Replacement
Neye ihtiyacın var
  1. HP Pavilion 17-e146us Screen Replacement, Screen: adım 1, 2 resimden 1. HP Pavilion 17-e146us Screen Replacement, Screen: adım 1, 2 resimden 2.
    • Open the laptop.
    • Remove the two stickers on the lower left and right-hand corner of the laptop screen.
    FixBot'a Sor
    Yorum Ekle
  2. HP Pavilion 17-e146us Screen Replacement: adım 2, 1 resimden 1.
    • Using a Phillips #0 screwdriver, remove the two 5 mm screws in the lower left and right-hand corner of the laptop screen.
    FixBot'a Sor
    Yorum Ekle
  3. HP Pavilion 17-e146us Screen Replacement: adım 3, 2 resimden 1. HP Pavilion 17-e146us Screen Replacement: adım 3, 2 resimden 2.
    • Place a spudger or opening tool between the laptop screen and the plastic laptop frame.
    • Apply light pressure to the spudger to separate the plastic laptop frame covering the edges of the laptop screen.
    • These silver pieces cover the laptop hinges and will need to be removed as well.
    FixBot'a Sor
    Yorum Ekle
  4. HP Pavilion 17-e146us Screen Replacement: adım 4, 1 resimden 1.
    • Using a Phillips #0 screwdriver, remove the four 4 mm screws in each corner of the laptop screen.
    • This will separate the laptop cover from the laptop screen frame.
    • Hold the laptop cover securely to prevent damage.
    FixBot'a Sor
    Yorum Ekle
  5. HP Pavilion 17-e146us Screen Replacement: adım 5, 2 resimden 1. HP Pavilion 17-e146us Screen Replacement: adım 5, 2 resimden 2.
    • Using a Phillips #0 screwdriver, remove the four 3 mm screws on the side of the frame, one in each corner.
    • This will release the laptop screen from the frame.
    • Hold the laptop screen and frame securely to prevent damage to the motherboard attachments.
    FixBot'a Sor
    Yorum Ekle
  6. HP Pavilion 17-e146us Screen Replacement: adım 6, 2 resimden 1. HP Pavilion 17-e146us Screen Replacement: adım 6, 2 resimden 2.
    • Remove laptop screen.
    • While removing the laptop screen, be careful not to destroy the tape connection or break the motherboard.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Emma Neumann
637 İtibar
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 23
Her zaman: 851
