Ana içeriğe geç
HP Pavilion 17-g192dx Cooling Fan Replacement
Neye ihtiyacın var
  1. HP Pavilion 17-g192dx Cooling Fan Replacement, Battery: adım 1, 3 resimden 1. HP Pavilion 17-g192dx Cooling Fan Replacement, Battery: adım 1, 3 resimden 2. HP Pavilion 17-g192dx Cooling Fan Replacement, Battery: adım 1, 3 resimden 3.
    • Turn off the laptop.
    • Slide the battery lock to the right until you see the open lock symbol.
  2. HP Pavilion 17-g192dx Cooling Fan Replacement: adım 2, 1 resimden 1.
    • Slide the battery release to the left until the battery pops up.
    • This may require significant force.
  3. HP Pavilion 17-g192dx Cooling Fan Replacement: adım 3, 2 resimden 1. HP Pavilion 17-g192dx Cooling Fan Replacement: adım 3, 2 resimden 2.
    • Lift the battery up.
  4. HP Pavilion 17-g192dx Cooling Fan Replacement, laptop: adım 4, 1 resimden 1.
    • Using the metal spudger, pry up the screw covers.
  5. HP Pavilion 17-g192dx Cooling Fan Replacement: adım 5, 1 resimden 1.
    • Remove the fifteen 7mm screws holding the back casing on using the Phillips #00 screwdriver.
  6. HP Pavilion 17-g192dx Cooling Fan Replacement: adım 6, 2 resimden 1. HP Pavilion 17-g192dx Cooling Fan Replacement: adım 6, 2 resimden 2.
    • Remove the 7mm screw holding the disc drive in place using the Phillips #00 head screwdriver.
  7. HP Pavilion 17-g192dx Cooling Fan Replacement: adım 7, 3 resimden 1. HP Pavilion 17-g192dx Cooling Fan Replacement: adım 7, 3 resimden 2. HP Pavilion 17-g192dx Cooling Fan Replacement: adım 7, 3 resimden 3.
    • Using an iFixit opening tool, push the disc drive away from the outer case.
    • Once the disk drive is out far enough, it easily slides out.
  8. HP Pavilion 17-g192dx Cooling Fan Replacement: adım 8, 3 resimden 1. HP Pavilion 17-g192dx Cooling Fan Replacement: adım 8, 3 resimden 2. HP Pavilion 17-g192dx Cooling Fan Replacement: adım 8, 3 resimden 3.
    • Remove the four 7mm screws holding the back resting plates on using the Phillips #00 screwdriver.
    • Using a metal spudger, lift up on the back resting plate until it pops off.
  9. HP Pavilion 17-g192dx Cooling Fan Replacement: adım 9, 2 resimden 1. HP Pavilion 17-g192dx Cooling Fan Replacement: adım 9, 2 resimden 2.
    • Remove the two 7 mm screws behind the plate using a Phillips #00 screwdriver.
  10. HP Pavilion 17-g192dx Cooling Fan Replacement: adım 10, 3 resimden 1. HP Pavilion 17-g192dx Cooling Fan Replacement: adım 10, 3 resimden 2. HP Pavilion 17-g192dx Cooling Fan Replacement: adım 10, 3 resimden 3.
    • Pry up on the case with an iFixit opening tool until you can feel a snap.
    • Pry around the remainder until you can separate the case from the keyboard with your hands.
    • Gently separate the two.
  11. HP Pavilion 17-g192dx Cooling Fan Replacement, Cooling Fan: adım 11, 3 resimden 1. HP Pavilion 17-g192dx Cooling Fan Replacement, Cooling Fan: adım 11, 3 resimden 2. HP Pavilion 17-g192dx Cooling Fan Replacement, Cooling Fan: adım 11, 3 resimden 3.
    • Remove the four 2mm screws on the heat sink with a Phillips #00 screwdriver.
    • Remove the heat sink.
    • When setting the heat sink down, set it face down to avoid putting the thermal paste on the work surface.
    • When reinstalling the heat sink, be sure to clean the contact surfaces and reapply fresh thermal paste.
  12. HP Pavilion 17-g192dx Cooling Fan Replacement: adım 12, 1 resimden 1.
    • Remove the two 5mm screws holding the fan in place using the Phillips #00 screwdriver.
  13. HP Pavilion 17-g192dx Cooling Fan Replacement: adım 13, 2 resimden 1. HP Pavilion 17-g192dx Cooling Fan Replacement: adım 13, 2 resimden 2.
    • Unplug the cooling fan from the motherboard.
    • Remove the cooling fan.
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 16
Son 30 gün: 26
Her zaman: 613
