Ana içeriğe geç
HP Pavilion N3350 RAM Replacement
Neye ihtiyacın var
    1. HP Pavilion N3350 RAM Replacement, RAM: adım 1, 1 resimden 1.
      • Locate the RAM on the bottom side of the laptop, the cover is secured by a 6 millimeter screw. Remove this with a Philips #1 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    2. HP Pavilion N3350 RAM Replacement: adım 2, 1 resimden 1.
      • Underneath are the RAM boards. They are secured by two plastic clips each. Locate these to continue removal.
      FixBot'a Sor
      Yorum Ekle
    3. HP Pavilion N3350 RAM Replacement: adım 3, 1 resimden 1.
      • Place your thumbs on two of the clips securing one board. Push outwards on the clips. This should pop the board up.
      FixBot'a Sor
      Yorum Ekle
    4. HP Pavilion N3350 RAM Replacement: adım 4, 1 resimden 1.
      • Repeat on second board. When both are released, they should appear as they do in the picture.
      FixBot'a Sor
      Yorum Ekle
    5. HP Pavilion N3350 RAM Replacement: adım 5, 1 resimden 1.
      • The RAM should be easily removed once released from the plastic clips.
      FixBot'a Sor
      Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Brandon Boisclair
530 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S3-G8, Peak Spring 2018 UMass Dartmouth, Team S3-G8, Peak Spring 2018 üyesi
UMASSD-PEAK-S18S3G8
3 Üyeler
71 adet Kılavuz yazıldı
1Rehber Yorum
Windows 98 Product Key?
Dudefoxlive - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 25
Her zaman: 459
