Ana içeriğe geç
Giriş
The heat sink draws heat away from the computer to cool it. The heat sink can often become dirty or need a new application of thermal paste to function properly.
Parçalar
Hiçbir parça belirtilmedi.
  1. Turn the laptop upside down with the battery compartment facing you.
    • Turn the laptop upside down with the battery compartment facing you.
  2. Slide the battery release latch to the right and hold in place.
    • Slide the battery release latch to the right and hold in place.
  3. Lift the front edge of the battery up and remove it from the compartment.
    • Lift the front edge of the battery up and remove it from the compartment.
  4. Apple Watch Kitleri
    Screen and battery repairs just got easier.
    Hemen Alışveriş Yapın
    Apple Watch Kitleri
  5. Position laptop with heat sink compartment facing you.
    • Position laptop with heat sink compartment facing you.
    • Locate the one 2x5 mm Torx screw.
  6. Remove the one 2x5 mm Torx screw securing the thermal cover with a #6 Torx screwdriver.
    • Remove the one 2x5 mm Torx screw securing the thermal cover with a #6 Torx screwdriver.
  7. Lift thermal cover to reveal heat sink. Remove and set aside thermal cover.
    • Lift thermal cover to reveal heat sink.
    • Remove and set aside thermal cover.
  8. Locate the four screws on each corner of heat sink. Unscrew the four 2x12 mm screws with a #00 Phillips screwdriver.
    • Locate the four screws on each corner of heat sink.
    • Unscrew the four 2x12 mm screws with a #00 Phillips screwdriver.
  9. Grab sides of heat sink and carefully lift from compartment. Due to adhesive bonding of heat sink to base, wiggling it side to side before lifting might help removal process.
    • Grab sides of heat sink and carefully lift from compartment.
    • Due to adhesive bonding of heat sink to base, wiggling it side to side before lifting might help removal process.
  10. To reapply thermal paste, check out iFixit's guide here.
    • To reapply thermal paste, check out iFixit's guide here.
Sonuç
Ashukang Kima Tabong
222 İtibar
2 adet Kılavuz yazıldı
Takım
UMass Dartmouth, Team 4-2, Catania Fall 2016 UMass Dartmouth, Team 4-2, Catania Fall 2016 üyesi
UMASSD-CATANIA-F16S4G2
3 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 1
Son 30 Gün: 3
Her zaman: 250
