Ana içeriğe geç
HP Pavilion x360 14-ba253cl Battery Replacement
Neye ihtiyacın var
  1. HP Pavilion x360 14-ba253cl Battery Replacement, Keyboard: adım 1, 1 resimden 1.
    • Use the Jimmy to remove the footpads located at the bottom of the laptop.
  2. HP Pavilion x360 14-ba253cl Battery Replacement: adım 2, 1 resimden 1.
    • Remove three 4.0mm Phillips #0 screws from the top of the cover.
    • Remove two 6.0mm Phillips #0 screws underneath each of the back footpads.
    • Remove one 4.mm Phillips #0 screw beneath the divot.
  3. HP Pavilion x360 14-ba253cl Battery Replacement: adım 3, 1 resimden 1.
    • Turn the computer onto its base, with the computer open and the keys facing upward.
  4. HP Pavilion x360 14-ba253cl Battery Replacement: adım 4, 1 resimden 1.
    • Use an opening pick to separate the keyboard from the base of the laptop.
  5. HP Pavilion x360 14-ba253cl Battery Replacement: adım 5, 1 resimden 1.
    • Raise the keyboard slightly to gain access to the touch pad and keyboard cables.
    • Using a spudger, lift up the plastic locks that connect the ribbon cable to the system board.
    • Use the blue plastic tab on the ribbon cable to pull it out from the system board.
    • Remove the keyboard from the laptop.
  6. HP Pavilion x360 14-ba253cl Battery Replacement, Battery: adım 6, 1 resimden 1.
    • Remove six 3mm Phillips #00 screws around the perimeter of the battery.
  7. HP Pavilion x360 14-ba253cl Battery Replacement: adım 7, 1 resimden 1.
    • Carefully lift the battery starting from the lower right corner and disconnect it from the system board.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
Thanks, it was useful
Oleg - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 28
Son 30 gün: 97
Her zaman: 8,417
