Ana içeriğe geç
HP Pavilion x360 14m-cd0005dx Motherboard Replacement
Neye ihtiyacın var
  1. HP Pavilion x360 14m-cd0005dx Motherboard Replacement, Back Cover: adım 1, 1 resimden 1.
    • Turn off and shut down the computer.
    • Disconnect the power adapter and all external devices connected to the computer.
    • Do not work with the device powered on. It may result in bodily harm through electric shock.
  2. HP Pavilion x360 14m-cd0005dx Motherboard Replacement: adım 2, 1 resimden 1.
    • Flip the device with the backplate up and with the hinge on the far side.
  3. HP Pavilion x360 14m-cd0005dx Motherboard Replacement: adım 3, 2 resimden 1. HP Pavilion x360 14m-cd0005dx Motherboard Replacement: adım 3, 2 resimden 2.
    • Use the opening tool to remove the rubber feet attached to the bottom of the device.
  4. HP Pavilion x360 14m-cd0005dx Motherboard Replacement: adım 4, 2 resimden 1. HP Pavilion x360 14m-cd0005dx Motherboard Replacement: adım 4, 2 resimden 2.
    • Remove all screws located on the bottom of the device:
    • Two Phillips #0 7.0mm screws
    • Three Phillips #00 4.5mm screws
    • Make sure to keep track of all screws removed from the device.
  5. HP Pavilion x360 14m-cd0005dx Motherboard Replacement: adım 5, 3 resimden 1. HP Pavilion x360 14m-cd0005dx Motherboard Replacement: adım 5, 3 resimden 2. HP Pavilion x360 14m-cd0005dx Motherboard Replacement: adım 5, 3 resimden 3.
    • Using the opening tool, carefully remove the bottom cover from the device.
  6. HP Pavilion x360 14m-cd0005dx Motherboard Replacement, Battery: adım 6, 3 resimden 1. HP Pavilion x360 14m-cd0005dx Motherboard Replacement, Battery: adım 6, 3 resimden 2. HP Pavilion x360 14m-cd0005dx Motherboard Replacement, Battery: adım 6, 3 resimden 3.
    • Use a #00 Phillips screwdriver to remove:
    • Six 2.5 mm screws
  7. HP Pavilion x360 14m-cd0005dx Motherboard Replacement: adım 7, 2 resimden 1. HP Pavilion x360 14m-cd0005dx Motherboard Replacement: adım 7, 2 resimden 2.
    • Carefully lift from the base and remove the battery.
  8. HP Pavilion x360 14m-cd0005dx Motherboard Replacement, Heat Sink and Fan: adım 8, 1 resimden 1.
    • Remove the tape that secures the fan to the computer.
  9. HP Pavilion x360 14m-cd0005dx Motherboard Replacement: adım 9, 2 resimden 1. HP Pavilion x360 14m-cd0005dx Motherboard Replacement: adım 9, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Find the fan cable
    • Use the Reverse Tweezers to unplug the fan cable
  10. HP Pavilion x360 14m-cd0005dx Motherboard Replacement: adım 10, 3 resimden 1. HP Pavilion x360 14m-cd0005dx Motherboard Replacement: adım 10, 3 resimden 2. HP Pavilion x360 14m-cd0005dx Motherboard Replacement: adım 10, 3 resimden 3.
    • Remove all screws securing the fan to the device:
    • Two Phillips #00 4.5mm screws
    • Four Phillips #00 4.5mm screws
  11. HP Pavilion x360 14m-cd0005dx Motherboard Replacement: adım 11, 2 resimden 1. HP Pavilion x360 14m-cd0005dx Motherboard Replacement: adım 11, 2 resimden 2.
    • Lift and remove the fan and heat sink from the device.
    • When removing the fan, there will be an adhesive strip attached to the bottom. There may be some resistance as the device is being removed. Use a spudger to hold the adhesive down during removal.
  12. HP Pavilion x360 14m-cd0005dx Motherboard Replacement, Motherboard: adım 12, 2 resimden 1. HP Pavilion x360 14m-cd0005dx Motherboard Replacement, Motherboard: adım 12, 2 resimden 2.
    • Remove all screws securing the motherboard to the device:
    • Ten Phillips #0 4.5mm screws
  13. HP Pavilion x360 14m-cd0005dx Motherboard Replacement: adım 13, 3 resimden 1. HP Pavilion x360 14m-cd0005dx Motherboard Replacement: adım 13, 3 resimden 2. HP Pavilion x360 14m-cd0005dx Motherboard Replacement: adım 13, 3 resimden 3.
    Satın Al
    • Use the Reverse Tweezers to disconnect the speaker cables from the motherboard.
  14. HP Pavilion x360 14m-cd0005dx Motherboard Replacement: adım 14, 2 resimden 1. HP Pavilion x360 14m-cd0005dx Motherboard Replacement: adım 14, 2 resimden 2.
    • Slide out the ribbon wire from the motherboard
  15. HP Pavilion x360 14m-cd0005dx Motherboard Replacement: adım 15, 2 resimden 1. HP Pavilion x360 14m-cd0005dx Motherboard Replacement: adım 15, 2 resimden 2.
    • Gently lift the motherboard out of the device
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 10
Her zaman: 723
