Ana içeriğe geç
HP ProBook 440 G6 Fan Replacement
Neye ihtiyacın var
  1. HP ProBook 440 G6 Fan Replacement, Lower Case: adım 1, 3 resimden 1. HP ProBook 440 G6 Fan Replacement, Lower Case: adım 1, 3 resimden 2. HP ProBook 440 G6 Fan Replacement, Lower Case: adım 1, 3 resimden 3.
    • Using a Phillips #0 Screwdriver, remove the two 5 mm screws on the front-facing side of the lower case.
    • Using a Phillips #0 Screwdriver, remove the remaining five 5 mm Phillips screws securing the lower case.
    • The two screws in the front of the backplate are of a differing size to the other five.
    FixBot'a Sor
    Yorum Ekle
  2. HP ProBook 440 G6 Fan Replacement: adım 2, 3 resimden 1. HP ProBook 440 G6 Fan Replacement: adım 2, 3 resimden 2. HP ProBook 440 G6 Fan Replacement: adım 2, 3 resimden 3.
    • Starting under the display, carefully use a plastic prying tool (iFixit opening tool) to disengage the retaining clips.
    • You may hear soft clicking sounds as the clips come undone.
    • Once a corner or edge starts to lift, slowly slide the tool along the edge to loosen more of the bottom panel.
    • Keep working around the edges until all the clips are loose.
    FixBot'a Sor
    Yorum Ekle
  3. HP ProBook 440 G6 Fan Replacement: adım 3, 3 resimden 1. HP ProBook 440 G6 Fan Replacement: adım 3, 3 resimden 2. HP ProBook 440 G6 Fan Replacement: adım 3, 3 resimden 3.
    • Gently lift the rear of the cover to disengage it from the computer.
    • Carefully remove the bottom cover from the computer.
    FixBot'a Sor
    Yorum Ekle
  4. HP ProBook 440 G6 Fan Replacement, Battery: adım 4, 2 resimden 1. HP ProBook 440 G6 Fan Replacement, Battery: adım 4, 2 resimden 2.
    • Using a Phillips #0 Screwdriver, remove the two 4mm Phillips screws that secure the battery to the computer.
    FixBot'a Sor
    Yorum Ekle
  5. HP ProBook 440 G6 Fan Replacement: adım 5, 1 resimden 1.
    • Use a tool to push the tab back on the bottom left of the battery.
    FixBot'a Sor
    Yorum Ekle
  6. HP ProBook 440 G6 Fan Replacement: adım 6, 3 resimden 1. HP ProBook 440 G6 Fan Replacement: adım 6, 3 resimden 2. HP ProBook 440 G6 Fan Replacement: adım 6, 3 resimden 3.
    • Lift the top of the battery.
    • Lift the battery out of the computer.
    FixBot'a Sor
    Yorum Ekle
  7. HP ProBook 440 G6 Fan Replacement, Fan: adım 7, 1 resimden 1.
    • Carefully disconnect the fan cable from the system board.
    FixBot'a Sor
    Yorum Ekle
  8. HP ProBook 440 G6 Fan Replacement: adım 8, 1 resimden 1.
    • Use a Phillips #0 screwdriver to remove the two 4 mm-long Phillips screws that secure the fan to the chassis.
    FixBot'a Sor
    Yorum Ekle
  9. HP ProBook 440 G6 Fan Replacement: adım 9, 3 resimden 1. HP ProBook 440 G6 Fan Replacement: adım 9, 3 resimden 2. HP ProBook 440 G6 Fan Replacement: adım 9, 3 resimden 3.
    • Lift the fan and remove it from the computer.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 44
Her zaman: 144
