Ana içeriğe geç
HP ProBook 455 G7 RAM Replacement
Neye ihtiyacın var
  1. HP ProBook 455 G7 RAM Replacement, Lower Case: adım 1, 1 resimden 1.
    • Before beginning, completely power off the laptop and unplug the charger and any peripheries.
    • Flip the laptop over so the lower case is facing up.
    • Use a Phillips #1 screwdriver to remove the seven 8 mm-long screws securing the lower case.
    FixBot'a Sor
    Yorum Ekle
  2. HP ProBook 455 G7 RAM Replacement: adım 2, 3 resimden 1. HP ProBook 455 G7 RAM Replacement: adım 2, 3 resimden 2. HP ProBook 455 G7 RAM Replacement: adım 2, 3 resimden 3.
    • Insert an opening tool into the seam between the lower case and chassis.
    • Pry around the entire perimeter until the lower case fully releases.
    • Lift and remove the lower case.
    FixBot'a Sor
    Yorum Ekle
  3. HP ProBook 455 G7 RAM Replacement, Battery: adım 3, 3 resimden 1. HP ProBook 455 G7 RAM Replacement, Battery: adım 3, 3 resimden 2. HP ProBook 455 G7 RAM Replacement, Battery: adım 3, 3 resimden 3.
    • Use a Phillips #1 screwdriver to remove the three 4 mm-long screws securing the battery.
    • Carefully lift the battery and remove it from the laptop.
    FixBot'a Sor
    Yorum Ekle
  4. HP ProBook 455 G7 RAM Replacement, RAM: adım 4, 1 resimden 1.
    • Two clips secure the RAM module in place, one on each side. Using your fingers, spread the clips away from the RAM module.
    FixBot'a Sor
    Yorum Ekle
  5. HP ProBook 455 G7 RAM Replacement: adım 5, 1 resimden 1.
    • The RAM stick should pop up at an angle.
    FixBot'a Sor
    Yorum Ekle
  6. HP ProBook 455 G7 RAM Replacement: adım 6, 1 resimden 1.
    • Carefully pull the module directly out of its socket.
    • Align the notch on the new RAM module with the slot in the connector.
    • Slide the module in at an angle, then press down until it clicks into place.
    • The HP ProBook 455 G7 typically supports DDR4 SO-DIMM RAM up to 32 GB (2 × 16 GB). Make sure both sticks are properly seated before reassembling.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Bir başkası bu kılavuzu tamamladı.
Andiany Reynoso
253 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-6, Botvin Fall 2025 UMass Dartmouth, Team 1-6, Botvin Fall 2025 üyesi
UMASSD-BOTVIN-F25S1G6
3 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 28
Her zaman: 155
