Ana içeriğe geç
HP ProBook 640 Fan Replacement
Neye ihtiyacın var
  1. HP ProBook 640 Fan Replacement, Battery: adım 1, 1 resimden 1.
    • Turn the laptop upside down to show the battery lock slider.
    • It is a black slider near the top, with a battery logo to the left and a lock sign to the right.
    FixBot'a Sor
    Yorum Ekle
  2. HP ProBook 640 Fan Replacement: adım 2, 1 resimden 1.
    • Slide the battery slider all the way to the left, towards the battery symbol.
    • You may also need to slide the other slider to the right of the battery slider, as shown in the picture.
    FixBot'a Sor
    Yorum Ekle
  3. HP ProBook 640 Fan Replacement: adım 3, 1 resimden 1.
    • Remove the battery by sliding it away from the laptop while holding the battery locker.
    • The battery should slide out with ease.
    FixBot'a Sor
    Yorum Ekle
  4. HP ProBook 640 Fan Replacement, Back Panel: adım 4, 2 resimden 1. HP ProBook 640 Fan Replacement, Back Panel: adım 4, 2 resimden 2.
    • Slide down and pull up on the cover to remove it.
    FixBot'a Sor
    Yorum Ekle
  5. HP ProBook 640 Fan Replacement, Midframe: adım 5, 3 resimden 1. HP ProBook 640 Fan Replacement, Midframe: adım 5, 3 resimden 2. HP ProBook 640 Fan Replacement, Midframe: adım 5, 3 resimden 3.
    • Remove the eight rubber screw plugs from the bottom and the two rubber screw plugs from the sides of the laptop using a paperclip.
    • Remove the fourteen 6 mm screws from the bottom of the laptop and the two 6 mm screws from the sides using a T8 Torx screwdriver.
    • Remove the six 4 mm screws that secure the midframe using a T8 Torx screwdriver.
    • Some of the screws are held in place by springs and cannot be fully removed, but can still be loosened.
    FixBot'a Sor
    Yorum Ekle
  6. HP ProBook 640 Fan Replacement: adım 6, 2 resimden 1. HP ProBook 640 Fan Replacement: adım 6, 2 resimden 2.
    • Remove the disk drive by gently pulling it out.
    • Remove the two 3 mm screws using a Phillips #1 screwdriver.
    • Only one screw is visible in the photo the second screw is located directly above it.
    FixBot'a Sor
    Yorum Ekle
  7. HP ProBook 640 Fan Replacement: adım 7, 2 resimden 1. HP ProBook 640 Fan Replacement: adım 7, 2 resimden 2.
    • Gently pull up on the midframe, gripping it from the inside.
    • This may take a small amount of force. If it feels stuck, check for missed screws. Go back to the previous steps and make sure you have removed all necessary screws.
    FixBot'a Sor
    Yorum Ekle
  8. HP ProBook 640 Fan Replacement, Fan: adım 8, 2 resimden 1. HP ProBook 640 Fan Replacement, Fan: adım 8, 2 resimden 2.
    • Loosen the two captive screws in the fan using a Phillips #1 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  9. HP ProBook 640 Fan Replacement: adım 9, 2 resimden 1. HP ProBook 640 Fan Replacement: adım 9, 2 resimden 2.
    • Carefully lift the fan and disconnect its cable from the motherboard.
    • Remove the fan from the laptop.
    • Avoid touching motherboard components directly to prevent static damage.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Taiyaba Asif
214 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 4-2, Biswokarma Fall 2025 UMass Dartmouth, Team 4-2, Biswokarma Fall 2025 üyesi
UMASSD-BISWOKARMA-F25S4G2
5 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 31
Her zaman: 259
