Ana içeriğe geç
HP ProBook 640 G2 Hard Drive Replacement
Neye ihtiyacın var
  1. HP ProBook 640 G2 Hard Drive Replacement, Battery: adım 1, 1 resimden 1.
    • Flip the laptop so the bottom is facing up.
    • Use a JIS J1 screwdriver to remove eight 6 mm screws from the bottom of the laptop case.
    • Use a Torx T9 screwdriver to remove the single 6 mm screw.
    FixBot'a Sor
    Yorum Ekle
  2. HP ProBook 640 G2 Hard Drive Replacement: adım 2, 1 resimden 1.
    • Use a plastic opening tool to carefully pry the bottom case.
    • Insert the end of the opening tool into the seam between the bottom and top case and slide it around the perimeter to release the clips.
    • Remove the bottom cover.
    FixBot'a Sor
    Yorum Ekle
  3. HP ProBook 640 G2 Hard Drive Replacement: adım 3, 3 resimden 1. HP ProBook 640 G2 Hard Drive Replacement: adım 3, 3 resimden 2. HP ProBook 640 G2 Hard Drive Replacement: adım 3, 3 resimden 3.
    • Use a JIS J1 screwdriver to remove the seven 6 mm screws securing the battery.
    • Lift the battery from the bottom edge and slide it out of the socket on the motherboard.
    FixBot'a Sor
    Yorum Ekle
  4. HP ProBook 640 G2 Hard Drive Replacement, Hard Drive: adım 4, 1 resimden 1.
    • Loosen the four JIS J1 captive screws on the hard drive tray.
    • Use the black tab on the hard drive tray and pull it toward the bottom of the laptop to remove the drive.
    FixBot'a Sor
    Yorum Ekle
  5. HP ProBook 640 G2 Hard Drive Replacement: adım 5, 3 resimden 1. HP ProBook 640 G2 Hard Drive Replacement: adım 5, 3 resimden 2. HP ProBook 640 G2 Hard Drive Replacement: adım 5, 3 resimden 3.
    • Use the JIS J1 screwdriver to remove the four 3.0 mm screws on the sides of the hard drive tray—two from each side.
    • Remove the old hard drive from the tray.
    FixBot'a Sor
    Yorum Ekle
Sonuç
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 12
Son 30 gün: 52
Her zaman: 242
