Ana içeriğe geç
HP ProBook 640 G2 RAM Replacement
Neye ihtiyacın var
  1. HP ProBook 640 G2 RAM Replacement, Battery: adım 1, 1 resimden 1.
    • Flip the laptop so the bottom is facing up.
    • Use a JIS J1 screwdriver to remove eight 6 mm screws from the bottom of the laptop case.
    • Use a Torx T9 screwdriver to remove the single 6 mm screw.
    FixBot'a Sor
    Yorum Ekle
  2. HP ProBook 640 G2 RAM Replacement: adım 2, 1 resimden 1.
    • Use a plastic opening tool to carefully pry the bottom case.
    • Insert the end of the opening tool into the seam between the bottom and top case and slide it around the perimeter to release the clips.
    • Remove the bottom cover.
    FixBot'a Sor
    Yorum Ekle
  3. HP ProBook 640 G2 RAM Replacement: adım 3, 3 resimden 1. HP ProBook 640 G2 RAM Replacement: adım 3, 3 resimden 2. HP ProBook 640 G2 RAM Replacement: adım 3, 3 resimden 3.
    • Use a JIS J1 screwdriver to remove the seven 6 mm screws securing the battery.
    • Lift the battery from the bottom edge and slide it out of the socket on the motherboard.
    FixBot'a Sor
    Yorum Ekle
  4. HP ProBook 640 G2 RAM Replacement, Hard Drive: adım 4, 1 resimden 1.
    • Loosen the four JIS J1 captive screws on the hard drive tray.
    • Use the black tab on the hard drive tray and pull it toward the bottom of the laptop to remove the drive.
    FixBot'a Sor
    Yorum Ekle
  5. HP ProBook 640 G2 RAM Replacement: adım 5, 3 resimden 1. HP ProBook 640 G2 RAM Replacement: adım 5, 3 resimden 2. HP ProBook 640 G2 RAM Replacement: adım 5, 3 resimden 3.
    • Use the JIS J1 screwdriver to remove the four 3.0 mm screws on the sides of the hard drive tray—two from each side.
    • Remove the old hard drive from the tray.
    FixBot'a Sor
    Yorum Ekle
  6. HP ProBook 640 G2 RAM Replacement, RAM: adım 6, 1 resimden 1.
    • Pull the disc drive out and set it aside.
    FixBot'a Sor
    Yorum Ekle
  7. HP ProBook 640 G2 RAM Replacement: adım 7, 2 resimden 1. HP ProBook 640 G2 RAM Replacement: adım 7, 2 resimden 2.
    • Slide a thin spudger or angled tweezers under the metal neck of the connector (as close to the head as possible) and lift straight up from the Wireless WLAN card.
    • Pull straight up on the black tab to disconnect the display cable.
    FixBot'a Sor
    Yorum Ekle
  8. HP ProBook 640 G2 RAM Replacement: adım 8, 3 resimden 1. HP ProBook 640 G2 RAM Replacement: adım 8, 3 resimden 2. HP ProBook 640 G2 RAM Replacement: adım 8, 3 resimden 3.
    • Use a JIS J1 screwdriver to remove the two 5 mm silver screws securing the hinge covers.
    • Turn the laptop over and open the top cover.
    • Use an opening tool to gently pry the plastic hinge covers off both hinges.
    • Lift the keyboard and pull it gently toward you to remove it from the laptop.
    FixBot'a Sor
    Yorum Ekle
  9. HP ProBook 640 G2 RAM Replacement: adım 9, 3 resimden 1. HP ProBook 640 G2 RAM Replacement: adım 9, 3 resimden 2. HP ProBook 640 G2 RAM Replacement: adım 9, 3 resimden 3.
    • Turn the keyboard assembly over so the motherboard is facing up.
    • Gently pull the metal retaining clips away from the RAM module.
    • The RAM module will pop up at an angle.
    • Pull the RAM card out of its slot and replace with a new one.
    • When replacing the RAM, slide it in at the same angle it was removed, making sure the metal teeth are aligned with the slot. Push down until it snaps into place between the metal arms.
    FixBot'a Sor
    Yorum Ekle
Sonuç
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Bir başkası bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 40
Her zaman: 220
