Giriş
This guide will instruct you on how to remove and replace the motherboard. Replacement of the motherboard may be necessary if the laptop is not turning on or booting.
Neye ihtiyacın var
Turn off and unplug the laptop.
Flip over the laptop so that the bottom backplate is exposed.
Bu adımda kullanılan alet:Tweezers$4.99
With the backplate removed, remove the four 3 mm screws securing the battery with a Phillips #1 screwdriver.
With the screws removed, disconnect the 3 wires connected to the battery.
Use a Phillips #0 Screwdriver to remove the four circled 3 mm screws.
Use the same screwdriver to remove the circled 4 mm screw.
