Ana içeriğe geç
HP Spectre x360 15" (15t-ap000) SSD Replacement
Neye ihtiyacın var
  1. HP Spectre x360 15" (15t-ap000) SSD Replacement, Unscrew the back cover: adım 1, 1 resimden 1.
    • Be sure to completely power off and unplug your laptop before you begin your repair. Make sure the laptop is not in standby, sleep, or hibernation mode.
    • Use a T5 driver to remove the following screws securing the back cover:
    • Six 4 mm-long screws
    • Two 7.8 mm-long screws
  2. HP Spectre x360 15" (15t-ap000) SSD Replacement, Loosen the back cover: adım 2, 2 resimden 1. HP Spectre x360 15" (15t-ap000) SSD Replacement, Loosen the back cover: adım 2, 2 resimden 2.
    • Use an opening tool or your fingers to pry up the back cover from the laptop.
    • Plastic clips hold the back cover lightly in place, so you may encounter some resistance.
    • If it feels like there is strong resistance, you may have a model that includes screws under the corner feet. Carefully pry the feet up to make sure they don't have screws.
  3. HP Spectre x360 15" (15t-ap000) SSD Replacement, Remove the back cover: adım 3, 2 resimden 1. HP Spectre x360 15" (15t-ap000) SSD Replacement, Remove the back cover: adım 3, 2 resimden 2.
    • Lift and remove the back cover.
    • During reassembly, gently press along the perimeter of the back cover to re-engage the clips.
  4. HP Spectre x360 15" (15t-ap000) SSD Replacement, Disconnect the battery: adım 4, 3 resimden 1. HP Spectre x360 15" (15t-ap000) SSD Replacement, Disconnect the battery: adım 4, 3 resimden 2. HP Spectre x360 15" (15t-ap000) SSD Replacement, Disconnect the battery: adım 4, 3 resimden 3.
    • Pry the edges of the battery connector with a spudger to loosen the connector from its motherboard socket.
    • Gently pull the connector parallel to the motherboard to disconnect it.
  5. HP Spectre x360 15" (15t-ap000) SSD Replacement, Remove the SSD: adım 5, 2 resimden 1. HP Spectre x360 15" (15t-ap000) SSD Replacement, Remove the SSD: adım 5, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Use your fingers or tweezers to peel the black plastic strip until you uncover the SSD.
  6. HP Spectre x360 15" (15t-ap000) SSD Replacement: adım 6, 1 resimden 1.
    • Use a Phillips screwdriver to remove the 2.8 mm-long screw securing the SSD to the motherboard.
  7. HP Spectre x360 15" (15t-ap000) SSD Replacement: adım 7, 2 resimden 1. HP Spectre x360 15" (15t-ap000) SSD Replacement: adım 7, 2 resimden 2.
    • Grasp the SSD edges with your fingers and pull it at a shallow angle parallel to the motherboard.
    • Remove the SSD.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Arthur Shi
283.608 İtibar
587 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
119 Üyeler
19.658 adet Kılavuz yazıldı
1Rehber Yorum
There are several types of M.2 slot supporting different technology, SATA or NVMe, so the first claim in the into is incorrect. Additionally, they are different sizes.
Ed Maher - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 15
Son 30 gün: 76
Her zaman: 4,236
