Ana içeriğe geç
HP Windows Mixed Reality Controllers TPC-Q044 Joystick Switch Replacement
Neye ihtiyacın var
  1. HP Windows Mixed Reality Controllers TPC-Q044 Joystick Switch Replacement, Batteries: adım 1, 3 resimden 1. HP Windows Mixed Reality Controllers TPC-Q044 Joystick Switch Replacement, Batteries: adım 1, 3 resimden 2. HP Windows Mixed Reality Controllers TPC-Q044 Joystick Switch Replacement, Batteries: adım 1, 3 resimden 3.
    • Slide the rear compartment cover in the direction of the arrow.
    • If replacing batteries, ensure the (+) and (-) on the battery match the (+) and (-) labeled in the battery compartment.
    FixBot'a Sor
    Yorum Ekle
  2. HP Windows Mixed Reality Controllers TPC-Q044 Joystick Switch Replacement, Shell: adım 2, 2 resimden 1. HP Windows Mixed Reality Controllers TPC-Q044 Joystick Switch Replacement, Shell: adım 2, 2 resimden 2.
    • Remove the four 4mm screws using a Phillips #00 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  3. HP Windows Mixed Reality Controllers TPC-Q044 Joystick Switch Replacement: adım 3, 3 resimden 1. HP Windows Mixed Reality Controllers TPC-Q044 Joystick Switch Replacement: adım 3, 3 resimden 2. HP Windows Mixed Reality Controllers TPC-Q044 Joystick Switch Replacement: adım 3, 3 resimden 3.
    • Grip the main body and pull the joystick outwards until the entire front panel pops off.
    • Remove the 6mm screw in the corner of the joystick well using a Phillips #00 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  4. HP Windows Mixed Reality Controllers TPC-Q044 Joystick Switch Replacement: adım 4, 2 resimden 1. HP Windows Mixed Reality Controllers TPC-Q044 Joystick Switch Replacement: adım 4, 2 resimden 2.
    • Use a spudger to pry apart the two halves of the assembly.
    • Work slowly, prying a small section at a time until the halves are completely separated.
    FixBot'a Sor
    Yorum Ekle
  5. HP Windows Mixed Reality Controllers TPC-Q044 Joystick Switch Replacement, Small Circuit Board: adım 5, 2 resimden 1. HP Windows Mixed Reality Controllers TPC-Q044 Joystick Switch Replacement, Small Circuit Board: adım 5, 2 resimden 2.
    • Using a Phillips #00 screwdriver, remove the four 4mm screws located on the joystick circuit board underneath the top half of the controller.
    FixBot'a Sor
    Yorum Ekle
  6. HP Windows Mixed Reality Controllers TPC-Q044 Joystick Switch Replacement: adım 6, 3 resimden 1. HP Windows Mixed Reality Controllers TPC-Q044 Joystick Switch Replacement: adım 6, 3 resimden 2. HP Windows Mixed Reality Controllers TPC-Q044 Joystick Switch Replacement: adım 6, 3 resimden 3.
    • Remove the orange flat cable by pulling the orange tab parallel to the circuit board.
    • Release the blue flat cable by lifting up the white latch with a spudger.
    FixBot'a Sor
    Yorum Ekle
  7. HP Windows Mixed Reality Controllers TPC-Q044 Joystick Switch Replacement, Joystick Switch: adım 7, 2 resimden 1. HP Windows Mixed Reality Controllers TPC-Q044 Joystick Switch Replacement, Joystick Switch: adım 7, 2 resimden 2.
    • The joystick controller is soldered directly to the circuit board. You can find instructions for removing soldered components here.
    • The joystick controller is secured by 12 solder connections. Once these have been desoldered, the controller can be removed.
    FixBot'a Sor
    Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Clement Cheung
643 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S18-G5, White Winter 2019 Cal Poly, Team S18-G5, White Winter 2019 üyesi
CPSU-WHITE-W19S18G5
2 Üyeler
14 adet Kılavuz yazıldı
3Kılavuz Yorumları
You can solder replacement Xbox One analog sticks right? I have some stick drift and can’t test this until my university reopens, but when it does I want to try fixing it.
Edit: I have the Dell controllers but they seem identical to the HP ones in this guide.
Vincent - Yanıt Paylaş
I think this might be the stick: https://www.mouser.com/ProductDetail/Alp...
Alps RKJXV 23 degree 10K ohm multi-directional switches
I haven’t soldered it yet so do not take my word as fact, it just looks right.
I have one issue post doing this. I reaoldered everything. The multimeter doesn't read OL anywhere BUT the controller will not power on when reassembled.
Layrinn - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 34
Her zaman: 1,761
