Ana içeriğe geç
HP Z2 Mini G3 CPU Fan Replacement
  1. HP Z2 Mini G3 CPU Fan Replacement, Access Panel: adım 1, 1 resimden 1.
    • Turn the device so the back-side of the device is facing you.
    • Be sure that the power is off and the A/C power cord has been disconnected before starting. Removing hardware while the power is on could damage the device or harm yourself.
    • Components of the device are subject to static damage. Work on a hard, grounded surface to prevent damage to the workstation.
    FixBot'a Sor
    Yorum Ekle
  2. HP Z2 Mini G3 CPU Fan Replacement: adım 2, 2 resimden 1. HP Z2 Mini G3 CPU Fan Replacement: adım 2, 2 resimden 2.
    • Slide and hold the latch in the direction of the engraved arrow (to the right).
    FixBot'a Sor
    Yorum Ekle
  3. HP Z2 Mini G3 CPU Fan Replacement: adım 3, 2 resimden 1. HP Z2 Mini G3 CPU Fan Replacement: adım 3, 2 resimden 2.
    • While holding the latch, lift the access panel upwards and towards yourself and set it aside upside-down.
    FixBot'a Sor
    Yorum Ekle
  4. HP Z2 Mini G3 CPU Fan Replacement, CPU Fan: adım 4, 1 resimden 1.
    • Rotate the device so the front side is facing you (the side with the power button) and locate the CPU fan.
    FixBot'a Sor
    Yorum Ekle
  5. HP Z2 Mini G3 CPU Fan Replacement: adım 5, 1 resimden 1.
    • Swing the fan upward, to a 90-degree angle.
    FixBot'a Sor
    Yorum Ekle
  6. HP Z2 Mini G3 CPU Fan Replacement: adım 6, 2 resimden 1. HP Z2 Mini G3 CPU Fan Replacement: adım 6, 2 resimden 2.
    • Carefully disconnect the CPU fan by pulling out the wires from the motherboard.
    FixBot'a Sor
    Yorum Ekle
  7. HP Z2 Mini G3 CPU Fan Replacement: adım 7, 1 resimden 1.
    • Swing the fan back down and carefully unhook the CPU fan notches by pulling each tab away from the heat sink holes.
    FixBot'a Sor
    Yorum Ekle
  8. HP Z2 Mini G3 CPU Fan Replacement: adım 8, 1 resimden 1.
    • Swing the fan up again and pull it out.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 14
Son 30 gün: 63
Her zaman: 2,337
