Ana içeriğe geç
HP Z2 Mini G3 Real-Time Clock Battery Replacement
    1. HP Z2 Mini G3 Real-Time Clock Battery Replacement, Access Panel: adım 1, 1 resimden 1.
      • Turn the device so the back-side of the device is facing you.
      • Be sure that the power is off and the A/C power cord has been disconnected before starting. Removing hardware while the power is on could damage the device or harm yourself.
      • Components of the device are subject to static damage. Work on a hard, grounded surface to prevent damage to the workstation.
      FixBot'a Sor
      Yorum Ekle
    2. HP Z2 Mini G3 Real-Time Clock Battery Replacement: adım 2, 2 resimden 1. HP Z2 Mini G3 Real-Time Clock Battery Replacement: adım 2, 2 resimden 2.
      • Slide and hold the latch in the direction of the engraved arrow (to the right).
      FixBot'a Sor
      Yorum Ekle
    3. HP Z2 Mini G3 Real-Time Clock Battery Replacement: adım 3, 2 resimden 1. HP Z2 Mini G3 Real-Time Clock Battery Replacement: adım 3, 2 resimden 2.
      • While holding the latch, lift the access panel upwards and towards yourself and set it aside upside-down.
      FixBot'a Sor
      Yorum Ekle
    1. HP Z2 Mini G3 Real-Time Clock Battery Replacement, Real-Time Clock Battery: adım 4, 1 resimden 1.
      • Rotate the device so the back-side is facing you and locate the RTC battery.
      • You may have to swing the CPU Fan and GPU Fan upwards to fully access the Real-Time Clock (RTC) Battery.
      FixBot'a Sor
      Yorum Ekle
    2. HP Z2 Mini G3 Real-Time Clock Battery Replacement: adım 5, 1 resimden 1.
      • Press the battery down and away to free it of the latches.
      • Use your hand to grab and lift the battery out of the socket.
      FixBot'a Sor
      Yorum Ekle
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 22
Son 30 gün: 116
Her zaman: 5,013
