Ana içeriğe geç
HP ZBook 15 Screen Replacement
Neye ihtiyacın var
  1. HP ZBook 15 Screen Replacement, Battery: adım 1, 2 resimden 1. HP ZBook 15 Screen Replacement, Battery: adım 1, 2 resimden 2.
    • Flip the laptop over.
    • Slide the lever with the battery symbol beside it firmly until the battery pops out.
    • Remove the battery from the laptop.
    FixBot'a Sor
    Yorum Ekle
  2. HP ZBook 15 Screen Replacement, Screen: adım 2, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Orient the laptop keyboard-side up.
    • Use tweezers to remove the adhesive covers for the screws.
    FixBot'a Sor
    Yorum Ekle
  3. HP ZBook 15 Screen Replacement: adım 3, 1 resimden 1.
    • Remove the two 6mm screws with a Phillips #0 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  4. HP ZBook 15 Screen Replacement: adım 4, 2 resimden 1. HP ZBook 15 Screen Replacement: adım 4, 2 resimden 2.
    • Pull the bezel away from the screen.
    • Be sure to go one edge at a time! Do not pull hard on the corners as it may crack the bezel.
    FixBot'a Sor
    Yorum Ekle
  5. HP ZBook 15 Screen Replacement: adım 5, 1 resimden 1.
    • Remove the four 3mm screws with a Phillips #0 screwdriver near the corners of the screen to remove the display.
    • Be careful not to confuse any screws. They are close together and you may remove the back cover instead of the display.
    FixBot'a Sor
    Yorum Ekle
  6. HP ZBook 15 Screen Replacement: adım 6, 2 resimden 1. HP ZBook 15 Screen Replacement: adım 6, 2 resimden 2.
    • Do not peel the tape from the side closest to the bottom of the screen panel! This may rip out the connector's wires.
    • Gently lower the screen and lay it face down on the keyboard.
    • Lift the corners of the tape closest to the top of the screen and peel toward the center carefully.
    • Slowly pull the tape away from the sides.
    • Lift the tape and disconnect the screen connector.
    • You can leave the tape stuck to the cable connector and still be able to remove it.
    FixBot'a Sor
    Yorum Ekle
Sonuç
9 farklı kişi bu kılavuzu tamamladı.
Grant Terris
2.888 İtibar
12 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 8-43, Amido Winter 2015 Cal Poly, Team 8-43, Amido Winter 2015 üyesi
CPSU-AMIDO-W15S8G43
4 Üyeler
19 adet Kılavuz yazıldı
3Kılavuz Yorumları
Worked great! Only caution that I would add is that on one of the machines I took apart, the adhesive strip behind the bottom of the bezel stuck to the bezel and not the circuit board behind. I had to carefully slide my finger between the adhesive strip and the bezel to separate them. Once the bezel was removed, I was able to stick the adhesive back down. I think this laptop may have been exposed to some sort of liquid, so this may not be a common issue.
dwakefield - Yanıt Paylaş
My ZBook 15u g5 does not have any adhesive covers around the screen. How do I replace?
H B - Yanıt Paylaş
Hello can i replace my hd screen with another fhd one?
Mohand Almohands - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 10
Son 7 gün: 34
Son 30 gün: 112
Her zaman: 18,373
