Ana içeriğe geç
HP ZBook 15 Screen Replacement
Neye ihtiyacın var
  1. HP ZBook 15 Screen Replacement, Battery: adım 1, 2 resimden 1. HP ZBook 15 Screen Replacement, Battery: adım 1, 2 resimden 2.
    • Flip the laptop over.
    • Slide the lever with the battery symbol beside it firmly until the battery pops out.
    • Remove the battery from the laptop.
  2. HP ZBook 15 Screen Replacement, Screen: adım 2, 1 resimden 1.
    • Orient the laptop keyboard-side up.
    • Use tweezers to remove the adhesive covers for the screws.
  3. HP ZBook 15 Screen Replacement: adım 3, 1 resimden 1.
    • Remove the two 6mm screws with a Phillips #0 screwdriver.
  4. HP ZBook 15 Screen Replacement: adım 4, 2 resimden 1. HP ZBook 15 Screen Replacement: adım 4, 2 resimden 2.
    • Pull the bezel away from the screen.
    • Be sure to go one edge at a time! Do not pull hard on the corners as it may crack the bezel.
  5. HP ZBook 15 Screen Replacement: adım 5, 1 resimden 1.
    • Remove the four 3mm screws with a Phillips #0 screwdriver near the corners of the screen to remove the display.
    • Be careful not to confuse any screws. They are close together and you may remove the back cover instead of the display.
  6. HP ZBook 15 Screen Replacement: adım 6, 2 resimden 1. HP ZBook 15 Screen Replacement: adım 6, 2 resimden 2.
    • Do not peel the tape from the side closest to the bottom of the screen panel! This may rip out the connector's wires.
    • Gently lower the screen and lay it face down on the keyboard.
    • Lift the corners of the tape closest to the top of the screen and peel toward the center carefully.
    • Slowly pull the tape away from the sides.
    • Lift the tape and disconnect the screen connector.
    • You can leave the tape stuck to the cable connector and still be able to remove it.
Sonuç
9 farklı kişi bu kılavuzu tamamladı.
Grant Terris
2.828 İtibar
12 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 8-43, Amido Winter 2015 Cal Poly, Team 8-43, Amido Winter 2015 üyesi
CPSU-AMIDO-W15S8G43
4 Üyeler
15 adet Kılavuz yazıldı
3 Yorum
Worked great! Only caution that I would add is that on one of the machines I took apart, the adhesive strip behind the bottom of the bezel stuck to the bezel and not the circuit board behind. I had to carefully slide my finger between the adhesive strip and the bezel to separate them. Once the bezel was removed, I was able to stick the adhesive back down. I think this laptop may have been exposed to some sort of liquid, so this may not be a common issue.
dwakefield - Yanıt
My ZBook 15u g5 does not have any adhesive covers around the screen. How do I replace?
H B - Yanıt
Hello can i replace my hd screen with another fhd one?
Mohand Almohands - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 29
Son 30 gün: 72
Her zaman: 16,320
