Ana içeriğe geç
HP ZBook 15 Wi-Fi Card Replacement
Neye ihtiyacın var
  1. HP ZBook 15 Wi-Fi Card Replacement, Battery: adım 1, 2 resimden 1. HP ZBook 15 Wi-Fi Card Replacement, Battery: adım 1, 2 resimden 2.
    • Flip the laptop over.
    • Slide the lever with the battery symbol beside it firmly until the battery pops out.
    • Remove the battery from the laptop.
  2. HP ZBook 15 Wi-Fi Card Replacement, Back Cover: adım 2, 1 resimden 1.
    • Slide the right lever firmly to the right.
    • Slide the cover towards yourself to remove it.
  3. HP ZBook 15 Wi-Fi Card Replacement, Wi-Fi Card: adım 3, 1 resimden 1.
    • Lift up the two tabs connected to wires.
  4. HP ZBook 15 Wi-Fi Card Replacement: adım 4, 2 resimden 1. HP ZBook 15 Wi-Fi Card Replacement: adım 4, 2 resimden 2.
    • Remove the two 3mm screws from the corners of the card with a Phillips #0 screwdriver.
    • Lift the card up and slide it out to disconnect it.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Grant Terris
2.828 İtibar
12 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 8-43, Amido Winter 2015 Cal Poly, Team 8-43, Amido Winter 2015 üyesi
CPSU-AMIDO-W15S8G43
4 Üyeler
15 adet Kılavuz yazıldı
Bir Yorum
I’m planning to upgrade my Zbook by installing a Wireless AC-capable WiFi module. I’ve found a cheap one that’s compatible according to the service manual: the Intel 7260HMW. However, it doesn’t have an HP SPS, it seems to have come from a DELL laptop.
Has anyone tried this? Will it work? I guess I’ll find out the hard way!
Hopefully, the seller will allow me to test the adapter before buying.
Luis Alejandro Araúz - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 11
Son 30 gün: 48
Her zaman: 5,477
