Giriş
Model Number : HP x2 10-p010wm
If you are having troubles charging your HP x2 10-p010wm and your device failed the battery diagnose test from HP, it is most likely that you need to a battery replacement.
This guide will show you how to take apart the screen in order to access to the battery. But we recommend you to check our troubleshooting page first.
Neye ihtiyacın var
Bir başkası bu kılavuzu tamamladı.
