Ana içeriğe geç
HP x2 10-p010wm Screen Replacement
Neye ihtiyacın var
  1. HP x2 10-p010wm Screen Replacement, Screen: adım 1, 2 resimden 1. HP x2 10-p010wm Screen Replacement, Screen: adım 1, 2 resimden 2.
    • Pull the screen away from the keyboard.
  2. HP x2 10-p010wm Screen Replacement: adım 2, 2 resimden 1. HP x2 10-p010wm Screen Replacement: adım 2, 2 resimden 2.
    • Insert a spudger into the space between the screen and computer and gently pry the two pieces apart. Continue this around the whole screen.
  3. HP x2 10-p010wm Screen Replacement: adım 3, 1 resimden 1.
    • Slowly disconnect the thin wire attaching the screen to the rest of the computer by holding one end and sliding it down.
    • Do not pull up too hard; slowly slide it towards the screen.
  4. HP x2 10-p010wm Screen Replacement: adım 4, 3 resimden 1. HP x2 10-p010wm Screen Replacement: adım 4, 3 resimden 2. HP x2 10-p010wm Screen Replacement: adım 4, 3 resimden 3.
    • Hold the screen with your thumb and push back on the plastic frame.
    • Slowly separate the plastic frame on all sides.
    • Be careful not to break the plastic frame.
  5. HP x2 10-p010wm Screen Replacement: adım 5, 2 resimden 1. HP x2 10-p010wm Screen Replacement: adım 5, 2 resimden 2.
    • Remove the frame.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Nathan Ojala
317 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S4-G3, Saloman Fall 2019 UMass Dartmouth, Team S4-G3, Saloman Fall 2019 üyesi
UMASSD-SALOMAN-F19S4G3
3 Üyeler
3 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 7
Her zaman: 381
