Ana içeriğe geç
HP x2 10-p010wm Speaker Replacement
Neye ihtiyacın var
  1. HP x2 10-p010wm Speaker Replacement, Battery: adım 1, 1 resimden 1.
    • Pull the screen away from the keyboard.
  2. HP x2 10-p010wm Speaker Replacement: adım 2, 2 resimden 1. HP x2 10-p010wm Speaker Replacement: adım 2, 2 resimden 2.
    • Insert a spudger into the space between the screen and computer and gently pry the two pieces apart. Continue this around the whole screen.
  3. HP x2 10-p010wm Speaker Replacement: adım 3, 1 resimden 1.
    • Slowly disconnect the thin wire attaching the screen to the rest of the computer by holding one end and sliding it down.
    • Do not pull up too hard; slowly slide it towards the screen.
  4. HP x2 10-p010wm Speaker Replacement: adım 4, 1 resimden 1.
    • Remove the eight 4mm Phillips #00 screws from the metal plate.
  5. HP x2 10-p010wm Speaker Replacement: adım 5, 3 resimden 1. HP x2 10-p010wm Speaker Replacement: adım 5, 3 resimden 2. HP x2 10-p010wm Speaker Replacement: adım 5, 3 resimden 3.
    • Slowly peel up any tape securing the wire to the metal cover.
    • Remove the metal cover to access the battery.
  6. HP x2 10-p010wm Speaker Replacement: adım 6, 1 resimden 1.
    • Remove the 4mm screw on the side.
  7. HP x2 10-p010wm Speaker Replacement: adım 7, 1 resimden 1.
    • Remove the black tape.
    • Pull the battery connector towards the battery to disconnect it from its socket.
  8. HP x2 10-p010wm Speaker Replacement: adım 8, 1 resimden 1.
    • Remove the battery.
  9. HP x2 10-p010wm Speaker Replacement, Speaker: adım 9, 2 resimden 1. HP x2 10-p010wm Speaker Replacement, Speaker: adım 9, 2 resimden 2.
    • Remove speakers on both sides.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Nathan Ojala
317 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S4-G3, Saloman Fall 2019 UMass Dartmouth, Team S4-G3, Saloman Fall 2019 üyesi
UMASSD-SALOMAN-F19S4G3
3 Üyeler
3 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 7
Her zaman: 169
