Ana içeriğe geç
HTC Desire 816 Speaker Replacement
Saleena Douangphachanh
Saleena Douangphachanh ve 4 diğer katkıda bulunanlar
En son May 7, 2024 tarihinde güncellendi
Tahmin yok
Orta
Daha İyi Resimler Gerekli
HTC is now known for there audio quality. The bottom speaker is a major item in the device so the user can have the full HTC sound experience. This guides purpose is geared towards the user replacing the speakers.
Neye ihtiyacın var
Aletler
Daha fazlasını göster…
  1. HTC Desire 816 Speaker Replacement, Battery: adım 1, 1 resimden 1.
    • Pry open the back panel by inserting the plastic opening tool on the left of the camera. We find this spot the easiest to get the tool under the panel.
  2. HTC Desire 816 Speaker Replacement: adım 2, 1 resimden 1.
    • Once you get an open spot, with a second plastic opening tool, slide down to the bottom of the phone to free the rest of side.
  3. HTC Desire 816 Speaker Replacement: adım 3, 1 resimden 1.
    • There is adhesive between the battery and the back panel. Take a nylon spudger to cut through the adhesive.
    • Be sure to use the correct tool for the job. Metal spudgers can puncture an unprotected battery, potentially causing a fire.
  4. HTC Desire 816 Speaker Replacement: adım 4, 1 resimden 1.
    • Once all way around the bottom, the panel should be broken free of the adhesive, and the rest of the panel should pop right off.
  5. HTC Desire 816 Speaker Replacement: adım 5, 1 resimden 1.
    • Insert a nylon spudger at the bottom of the battery and lift up to remove the battery.
  6. HTC Desire 816 Speaker Replacement: adım 6, 1 resimden 1.
    • There is adhesive on the other side of the battery as well, take the nylon spudger used to get off the panel and cut through.
  7. HTC Desire 816 Speaker Replacement: adım 7, 1 resimden 1.
    • Carefully lift battery backside first to disconnect the white connector.
  8. HTC Desire 816 Speaker Replacement, Bottom Speakers: adım 8, 1 resimden 1.
    • Using the T5 screw driver, unscrew the following screws.
  9. HTC Desire 816 Speaker Replacement: adım 9, 1 resimden 1.
    • Using the T5 screw driver remove the remaining screw at the bottom right corner of the phone.
  10. HTC Desire 816 Speaker Replacement: adım 10, 1 resimden 1.
    • Lift and remove black plastic casing with a nylon spudger to access the motherboard and speaker.
  11. HTC Desire 816 Speaker Replacement: adım 11, 1 resimden 1.
    • Using the PH000 unscrew the following screws that are holding down the motherboard.
  12. HTC Desire 816 Speaker Replacement: adım 12, 1 resimden 1.
    • Using the PH000 screw driver, unscrew the remaining screw.
  13. HTC Desire 816 Speaker Replacement: adım 13, 1 resimden 1.
    • Gently disconnect the wire located on the right side of the device from the bottom motherboard .
  14. HTC Desire 816 Speaker Replacement: adım 14, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Using a pair of tweezers, gently grab and lift the motherboard.
  15. HTC Desire 816 Speaker Replacement: adım 15, 1 resimden 1.
    • Using a pair of tweezers, gently grab and remove the speaker.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
618 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 5-3, Landers Spring 2016 UMass Dartmouth, Team 5-3, Landers Spring 2016 üyesi
UMASSD-LANDERS-S16S5G3
3 Üyeler
12 adet Kılavuz yazıldı
Bir Yorum
Where do you acquire new speakers? Can you tell me if the speakers are as powerful as the ones in the M8
Peter Ford - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 26
Her zaman: 4,077
