Ana içeriğe geç
HTC Desire V Button Assembly Replacement
William McCusker
William McCusker ve 4 diğer katkıda bulunanlar
En son October 22, 2021 tarihinde güncellendi
15 - 20 dakika
Orta
Daha İyi Resimler Gerekli
This guide will show you how to replace the Navigation Board of the HTC Desire V smartphone.
Neye ihtiyacın var
Aletler
Daha fazlasını göster…
  1. HTC Desire V Button Assembly Replacement, Battery: adım 1, 3 resimden 1. HTC Desire V Button Assembly Replacement, Battery: adım 1, 3 resimden 2. HTC Desire V Button Assembly Replacement, Battery: adım 1, 3 resimden 3.
    • Gently pry back cover away from phone.
    • If you are having difficulty you may need to use a Spudger or plastic opener.
  2. HTC Desire V Button Assembly Replacement: adım 2, 3 resimden 1. HTC Desire V Button Assembly Replacement: adım 2, 3 resimden 2. HTC Desire V Button Assembly Replacement: adım 2, 3 resimden 3.
    • Lever the battery out from the bottom end first.
    • Do not bend or puncture the battery.
  3. HTC Desire V Button Assembly Replacement, Midframe: adım 3, 3 resimden 1. HTC Desire V Button Assembly Replacement, Midframe: adım 3, 3 resimden 2. HTC Desire V Button Assembly Replacement, Midframe: adım 3, 3 resimden 3.
    • Use a Torx T5 screwdriver to unscrew and remove five 3.0 mm screws from the rear frame.
  4. HTC Desire V Button Assembly Replacement: adım 4, 3 resimden 1. HTC Desire V Button Assembly Replacement: adım 4, 3 resimden 2. HTC Desire V Button Assembly Replacement: adım 4, 3 resimden 3.
    • Use an opening tool or a spudger to gently remove the rear frame.
  5. HTC Desire V Button Assembly Replacement, Button Assembly: adım 5, 2 resimden 1. HTC Desire V Button Assembly Replacement, Button Assembly: adım 5, 2 resimden 2.
    • Remove the connector on left side of the Navigation board by unplugging/prying the orange ribbon.
  6. HTC Desire V Button Assembly Replacement: adım 6, 2 resimden 1. HTC Desire V Button Assembly Replacement: adım 6, 2 resimden 2.
    • Gently unplug and remove aerial cable (black antenna) from bottom plug.
  7. HTC Desire V Button Assembly Replacement: adım 7, 2 resimden 1. HTC Desire V Button Assembly Replacement: adım 7, 2 resimden 2.
    • Nav Board will be stuck down by glue.
    • Pull gently from the right end of the board, being careful of its flexibility.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
William McCusker
1.096 İtibar
9 adet Kılavuz yazıldı
Ekip
Clemson, Team 14-3, Shirley Winter 2015 Clemson, Team 14-3, Shirley Winter 2015 üyesi
CLEM-SHIRLEY-W15S14G3
6 Üyeler
18 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 7
Her zaman: 347
