Ana içeriğe geç
HTC EVO Design 4G Headphone Jack Replacement
Neye ihtiyacın var
  1. HTC EVO Design 4G Headphone Jack Replacement, Screen: adım 1, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Tools: Phillips #000 Screwdriver, T4 Torx Screwdriver, Safety Pry Tool (Guitar pick), Tweezers
    FixBot'a Sor
    Yorum Ekle
  2. HTC EVO Design 4G Headphone Jack Replacement, Removing Casing: adım 2, 1 resimden 1.
    • Use fingers on either end of the button edges of the phone to pull back cover off. It should slide off.
    FixBot'a Sor
    Yorum Ekle
  3. HTC EVO Design 4G Headphone Jack Replacement, Removing Battery: adım 3, 2 resimden 1. HTC EVO Design 4G Headphone Jack Replacement, Removing Battery: adım 3, 2 resimden 2.
    • When open, pull on “Open” tab and it should rotate towards you
    • Grab the bottom edge of the battery and pull it toward you
    FixBot'a Sor
    Yorum Ekle
  4. HTC EVO Design 4G Headphone Jack Replacement, Removing Casing: adım 4, 2 resimden 1. HTC EVO Design 4G Headphone Jack Replacement, Removing Casing: adım 4, 2 resimden 2.
    • On the side of the top casing on the phone there should be a slot. Use your safety pry tool (guitar pick) pry around the perimeter of the casing to remove it
    • Info*: The adhesive tape that you may find will not be necessary for replacement later
    FixBot'a Sor
    Yorum Ekle
  5. HTC EVO Design 4G Headphone Jack Replacement, Removing Screws: adım 5, 2 resimden 1. HTC EVO Design 4G Headphone Jack Replacement, Removing Screws: adım 5, 2 resimden 2.
    • Remove the two Phillips screws to release the casing above the port
    • Remove the top and bottom pairs of Torx screws.
    • Remove the middle pair of two Phillips screws.
    FixBot'a Sor
    Yorum Ekle
  6. HTC EVO Design 4G Headphone Jack Replacement, Removing Casing: adım 6, 3 resimden 1. HTC EVO Design 4G Headphone Jack Replacement, Removing Casing: adım 6, 3 resimden 2. HTC EVO Design 4G Headphone Jack Replacement, Removing Casing: adım 6, 3 resimden 3.
    • To remove the remaining cover, lift the side port, which was previously uncovered, then lift the outer shell from the bottom of the phone and slide it forward
    FixBot'a Sor
    Yorum Ekle
  7. HTC EVO Design 4G Headphone Jack Replacement, Removing Screws Continued: adım 7, 2 resimden 1. HTC EVO Design 4G Headphone Jack Replacement, Removing Screws Continued: adım 7, 2 resimden 2.
    • Remove the two revealed screws on the outside (Torx = red, Phillips = orange), and then remove the two phillips on the bottom of the phone
    FixBot'a Sor
    Yorum Ekle
  8. HTC EVO Design 4G Headphone Jack Replacement, Removing Rear Housing: adım 8, 2 resimden 1. HTC EVO Design 4G Headphone Jack Replacement, Removing Rear Housing: adım 8, 2 resimden 2.
    • Remove the rear housing by prying around the edge with your Safety Pry Tool
    FixBot'a Sor
    Yorum Ekle
  9. HTC EVO Design 4G Headphone Jack Replacement, Pull the Plug: adım 9, 1 resimden 1.
    • Unplug the wire connecting the vibrator to the board with your tweezers
    FixBot'a Sor
    Yorum Ekle
  10. HTC EVO Design 4G Headphone Jack Replacement, Like a Book: adım 10, 1 resimden 1.
    • Unfold motherboard from the screen (open carefully like a book)
    FixBot'a Sor
    Yorum Ekle
  11. HTC EVO Design 4G Headphone Jack Replacement, Flex Cables: adım 11, 1 resimden 1.
    • Disconnect the two aluminum flex cables
    FixBot'a Sor
    Yorum Ekle
  12. HTC EVO Design 4G Headphone Jack Replacement, Broken Bond: adım 12, 1 resimden 1.
    • The flex cables should be the only binding and after being removed should leave you with the separate screen
    FixBot'a Sor
    Yorum Ekle
  13. HTC EVO Design 4G Headphone Jack Replacement, Headphone Jack: adım 13, 2 resimden 1. HTC EVO Design 4G Headphone Jack Replacement, Headphone Jack: adım 13, 2 resimden 2.
    Desoldering Pump
    $3.99
    • Use solder sucker to remove solder from the front of head phone jack
    • Use solder sucker to remove solder from the back of head phone jack
    • There are 5 soldering locations from the top view and 5 locations from the bottom view
    • Remove the piece of tape covering the underside of the headphone jack. It will not have to be reattached
    • Refer to the How To Solder and Desolder Connections guie if needed
    • Solder sucker will be very hot
    FixBot'a Sor
    Yorum Ekle
Sonuç
Lilian Nguyen
208 İtibar
2 adet Kılavuz yazıldı
Ekip
IUPUI, Team S3-G2, Harley Spring 2017 IUPUI, Team S3-G2, Harley Spring 2017 üyesi
IUPUI-HARLEY-S17S3G2
4 Üyeler
4 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 45
Her zaman: 496
