Ana içeriğe geç
HTC Touch Camera Lens Replacement
Neye ihtiyacın var
    1. HTC Touch Camera Lens Replacement, Camera Lens: adım 1, 1 resimden 1.
      • Slide the back panel upward using the grip at the bottom until it releases.
      • Lift and remove the panel.
      FixBot'a Sor
      Yorum Ekle
    2. HTC Touch Camera Lens Replacement: adım 2, 1 resimden 1.
      • Use your fingers to grip the battery and remove it from its compartment.
      • Set it aside in a safe place.
      FixBot'a Sor
      Yorum Ekle
    3. HTC Touch Camera Lens Replacement: adım 3, 1 resimden 1.
      • Remove the 4 torx-head screws in the corners of the phone using the T5 Torx Screwdriver.
      • Keep the screws in a safe place so you don’t lose them.
      FixBot'a Sor
      Yorum Ekle
    4. HTC Touch Camera Lens Replacement: adım 4, 2 resimden 1. HTC Touch Camera Lens Replacement: adım 4, 2 resimden 2.
      • Use the plastic opening tool to remove the front panel from the phone.
      • Place a spudger or an opening tool under the edge of the press connector and pry straight up to disconnect it.
      • Make sure to pry under the edge of the connector itself, and not under the socket on the board. Otherwise, you risk permanently damaging the socket.
      • To reconnect, align the connector carefully over its socket and press down with your fingertip—first on one of the short sides, then the other—until it clicks into place. Don't try to force the connector into place. If you're having trouble, reposition it and try again.
      FixBot'a Sor
      Yorum Ekle
    5. HTC Touch Camera Lens Replacement: adım 5, 1 resimden 1.
      • Unscrew the torx-head screws at the base of the LCD screen using the T5 Torx Screwdriver.
      FixBot'a Sor
      Yorum Ekle
    6. HTC Touch Camera Lens Replacement: adım 6, 2 resimden 1. HTC Touch Camera Lens Replacement: adım 6, 2 resimden 2.
      • Seperate the motherboard from the black plastic casing.
      • Unplug the black and red wire from the motherboard.
      • Unplug the black and red wire from the black plastic casing.
      FixBot'a Sor
      Yorum Ekle
    7. HTC Touch Camera Lens Replacement: adım 7, 1 resimden 1.
      • Use a spudger to lift the black flap lock next to the orange ribbon cable and slide the cable from the socket.
      • Remove the LCD screen.
      FixBot'a Sor
      Yorum Ekle
    8. HTC Touch Camera Lens Replacement: adım 8, 1 resimden 1.
      • Remove the camera lens from the motherboard using the plastic opening tool.
      • Align and insert the new camera lens into the opening. Press it into place until it is secure.
      FixBot'a Sor
      Yorum Ekle
Sonuç
You've successfully replaced your HTC Touch's camera lens! Test your camera to ensure the new lens works properly and your images are clear. To reassemble your device, follow these instructions in reverse order.
2 farklı kişi bu kılavuzu tamamladı.
Sehyun
69 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 15-12, Regan Spring 2011 Cal Poly, Team 15-12, Regan Spring 2011 üyesi
CPSU-REGAN-S11S15G12
4 Üyeler
45 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 14
Son 30 gün: 38
Her zaman: 3,035
