Ana içeriğe geç
HTC Touch Pro CDMA Verizon Screen Replacement
Neye ihtiyacın var
    1. HTC Touch Pro CDMA Verizon Screen Replacement, Battery: adım 1, 1 resimden 1.
      • Remove the back cover (not pictured) to your phone.
      FixBot'a Sor
      Yorum Ekle
    2. HTC Touch Pro CDMA Verizon Screen Replacement: adım 2, 2 resimden 1. HTC Touch Pro CDMA Verizon Screen Replacement: adım 2, 2 resimden 2.
      • To remove the battery, place your thumb beneath the tab and begin to lift.
      • Pinching the battery, lift up at an angle from the bottom of the phone.
      FixBot'a Sor
      Yorum Ekle
    1. HTC Touch Pro CDMA Verizon Screen Replacement, Basic Parts: adım 3, 1 resimden 1.
      • Place the battery in a container off to the side. If you do this for every step beyond this point, you will keep better track of your parts and make reassembling the device far easier when you get around to it.
      • It might not be necessary, but we recommend using an anti-static bracelet or anti-static mat from this point on. Any charge on your finger tips may cause harm to the device.
      FixBot'a Sor
      Yorum Ekle
    2. HTC Touch Pro CDMA Verizon Screen Replacement: adım 4, 3 resimden 1. HTC Touch Pro CDMA Verizon Screen Replacement: adım 4, 3 resimden 2. HTC Touch Pro CDMA Verizon Screen Replacement: adım 4, 3 resimden 3.
      • Use a T6 screwdriver to remove the four screws on the rear plate of the HTC Touch Pro.
      • Place your screws in a bag labeled with where they came from, what screwdriver you used, and the order in which you removed them. For example, this bag would say "Rear casing. T6. #1."
      FixBot'a Sor
      Yorum Ekle
    3. HTC Touch Pro CDMA Verizon Screen Replacement: adım 5, 3 resimden 1. HTC Touch Pro CDMA Verizon Screen Replacement: adım 5, 3 resimden 2. HTC Touch Pro CDMA Verizon Screen Replacement: adım 5, 3 resimden 3.
      • Next, remove the casing that covers the camera and motherboard.
      • To do this, place your thumbnail in any of the grooves along either side and pry it open.
      FixBot'a Sor
      Yorum Ekle
    4. HTC Touch Pro CDMA Verizon Screen Replacement: adım 6, 2 resimden 1. HTC Touch Pro CDMA Verizon Screen Replacement: adım 6, 2 resimden 2.
      • Insert your spudger along the slit between the keyboard and the external casing. Pry open as shown.
      • Careful! The ribbon connecting the keyboard to the motherboard will still connect the two halves of the phone when you separate them. Be sure to take your time and move slowly to avoid damage to the cable.
      FixBot'a Sor
      Yorum Ekle
    5. HTC Touch Pro CDMA Verizon Screen Replacement: adım 7, 3 resimden 1. HTC Touch Pro CDMA Verizon Screen Replacement: adım 7, 3 resimden 2. HTC Touch Pro CDMA Verizon Screen Replacement: adım 7, 3 resimden 3.
      • Remove the keyboard ribbon from the motherboard. To do this, simply grasp the ribbon at its base and pry it up at an angle. The ribbon has a metal end that is easily removed from the motherboard.
      FixBot'a Sor
      Yorum Ekle
    6. HTC Touch Pro CDMA Verizon Screen Replacement: adım 8, 3 resimden 1. HTC Touch Pro CDMA Verizon Screen Replacement: adım 8, 3 resimden 2. HTC Touch Pro CDMA Verizon Screen Replacement: adım 8, 3 resimden 3.
      • Using a Phillips Head size 0 screwdriver, remove the 3 screws holding in the battery compartment.
      • Remove the ribbon covering the battery compartment by pinching it at the base and lifting.
      FixBot'a Sor
      Yorum Ekle
    1. HTC Touch Pro CDMA Verizon Screen Replacement, Keyboard: adım 9, 1 resimden 1.
      • Move the black slider over to the side without the keyboard ribbon. This is done as to allow the display ribbon to slide out later.
      • Using a PH 0 screwdriver, remove the 4 screws on the black slider.
      FixBot'a Sor
      Yorum Ekle
    2. HTC Touch Pro CDMA Verizon Screen Replacement: adım 10, 2 resimden 1. HTC Touch Pro CDMA Verizon Screen Replacement: adım 10, 2 resimden 2.
      • Pry the keyboard away from the screen. Open on the side containing the keyboard ribbon.
      FixBot'a Sor
      Yorum Ekle
    1. HTC Touch Pro CDMA Verizon Screen Replacement, Screen: adım 11, 2 resimden 1. HTC Touch Pro CDMA Verizon Screen Replacement, Screen: adım 11, 2 resimden 2.
      • Remove the four screws on the back of the screen assembly using the PH #0 screwdriver.
      • Move the silver slider across the phone so that you are able to pry the back off without damaging the display ribbon.
      FixBot'a Sor
      Yorum Ekle
    2. HTC Touch Pro CDMA Verizon Screen Replacement: adım 12, 2 resimden 1. HTC Touch Pro CDMA Verizon Screen Replacement: adım 12, 2 resimden 2.
      • Pry the rear of the screen assembly off from the side opposite to the display ribbon using the spudger
      FixBot'a Sor
      Yorum Ekle
    3. HTC Touch Pro CDMA Verizon Screen Replacement: adım 13, 3 resimden 1. HTC Touch Pro CDMA Verizon Screen Replacement: adım 13, 3 resimden 2. HTC Touch Pro CDMA Verizon Screen Replacement: adım 13, 3 resimden 3.
      • Remove the connected circuit board components behind the phone's navigation buttons.
      • Remove the four circuit board screws using the PH #0 screwdriver
      FixBot'a Sor
      Yorum Ekle
    4. HTC Touch Pro CDMA Verizon Screen Replacement: adım 14, 2 resimden 1. HTC Touch Pro CDMA Verizon Screen Replacement: adım 14, 2 resimden 2.
      • Push on the back of the board gently to remove the navigation buttons on the front.
      • Flip the phone to the front and remove the four screws holding the circuit board to the phone frame using the PH #0 screwdriver.
      • Replace the navigation buttons as necessary.
      FixBot'a Sor
      Yorum Ekle
    5. HTC Touch Pro CDMA Verizon Screen Replacement: adım 15, 2 resimden 1. HTC Touch Pro CDMA Verizon Screen Replacement: adım 15, 2 resimden 2.
      • Remove the two screws at the top of the screen using the PH #0 screwdriver.
      • Remove the beige piece after the screws have been removed as shown.
      FixBot'a Sor
      Yorum Ekle
    6. HTC Touch Pro CDMA Verizon Screen Replacement: adım 16, 2 resimden 1. HTC Touch Pro CDMA Verizon Screen Replacement: adım 16, 2 resimden 2.
      • Push gently on the back of the screen to release the glue holding it to the phone frame.
      • Peel the screen from the frame to completely separate the two components.
      • The glue between the screen and the phone frame is the only piece holding the two components together at this step.
      FixBot'a Sor
      Yorum Ekle
Sonuç
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
2 farklı kişi bu kılavuzu tamamladı.
Jack Bowen
79 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 20-67, Walters Spring 2011 Cal Poly, Team 20-67, Walters Spring 2011 üyesi
CPSU-WALTERS-S11S20G67
4 Üyeler
45 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 33
Her zaman: 3,077
