Ana içeriğe geç
HTC Trophy Volume Buttons Replacement
Neye ihtiyacın var
  1. HTC Trophy Volume Buttons Replacement, Battery: adım 1, 3 resimden 1. HTC Trophy Volume Buttons Replacement, Battery: adım 1, 3 resimden 2. HTC Trophy Volume Buttons Replacement, Battery: adım 1, 3 resimden 3.
    • Power off the phone before starting.
    • Remove the back panel by inserting the IFixIt opening tool into gap at the top of the rear and prying upward.
  2. HTC Trophy Volume Buttons Replacement: adım 2, 3 resimden 1. HTC Trophy Volume Buttons Replacement: adım 2, 3 resimden 2. HTC Trophy Volume Buttons Replacement: adım 2, 3 resimden 3.
    • Remove the battery by inserting the IFixIt opening tool into the small gap between the battery and the surrounding plastic.
    • Apply a small force towards the bottom of the phone and lift upwards.
    • Be careful not to puncture the battery.
  3. HTC Trophy Volume Buttons Replacement, Display Assembly: adım 3, 3 resimden 1. HTC Trophy Volume Buttons Replacement, Display Assembly: adım 3, 3 resimden 2. HTC Trophy Volume Buttons Replacement, Display Assembly: adım 3, 3 resimden 3.
    • Remove the 5 screws holding the two phone halves together.
    • Three 4mm long T5 Torx screws.
    • Press a T5 Torx screwdriver into the void sticker and remove the 4mm long T5 Torx screw.
    • One 4mm long Philips #000 screw.
    • Remove the installed SIM card if one is present.
  4. HTC Trophy Volume Buttons Replacement: adım 4, 3 resimden 1. HTC Trophy Volume Buttons Replacement: adım 4, 3 resimden 2. HTC Trophy Volume Buttons Replacement: adım 4, 3 resimden 3.
    • Insert the IFixIt opening tool into the seem of the plastic around the edge of the phone and pry the two halves apart.
    • There are small plastic clips holding the phone together. Slide the opening tool around the edge until it clicks apart to avoid damage.
    • The volume button will fall out when the phone is opened.
    • The black sticker beneath the battery will rip once the phone is separated.
  5. HTC Trophy Volume Buttons Replacement: adım 5, 3 resimden 1. HTC Trophy Volume Buttons Replacement: adım 5, 3 resimden 2. HTC Trophy Volume Buttons Replacement: adım 5, 3 resimden 3.
    • Remove the three screws holding the mother board to the display assembly.
    • One 2mm long Philips #000 screw.
    • Two 4mm long T5 Torx screws in the holes of the plastic.
  6. HTC Trophy Volume Buttons Replacement: adım 6, 3 resimden 1. HTC Trophy Volume Buttons Replacement: adım 6, 3 resimden 2. HTC Trophy Volume Buttons Replacement: adım 6, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Remove the black tape cover the ribbon cable connectors with tweezers.
    • Disconnect the ribbon cables from the connectors.
    • Ribbon cables are extremely fragile.
  7. HTC Trophy Volume Buttons Replacement: adım 7, 2 resimden 1. HTC Trophy Volume Buttons Replacement: adım 7, 2 resimden 2.
    • Remove power button from the top of the phone with tweezers.
  8. HTC Trophy Volume Buttons Replacement: adım 8, 3 resimden 1. HTC Trophy Volume Buttons Replacement: adım 8, 3 resimden 2. HTC Trophy Volume Buttons Replacement: adım 8, 3 resimden 3.
    • Use the iFixit opening tool to separate the motherboard from the display assembly.
  9. HTC Trophy Volume Buttons Replacement, Motherboard: adım 9, 3 resimden 1. HTC Trophy Volume Buttons Replacement, Motherboard: adım 9, 3 resimden 2. HTC Trophy Volume Buttons Replacement, Motherboard: adım 9, 3 resimden 3.
    • Remove the plastic piece off of the motherboard.
    • Put pressure outwards to release these clips with the iFixit opening tool and you fingers.
  10. HTC Trophy Volume Buttons Replacement, Volume Buttons: adım 10, 3 resimden 1. HTC Trophy Volume Buttons Replacement, Volume Buttons: adım 10, 3 resimden 2. HTC Trophy Volume Buttons Replacement, Volume Buttons: adım 10, 3 resimden 3.
    Satın Al
    • Peel back the protective tape with tweezers to expose the solder.
  11. HTC Trophy Volume Buttons Replacement: adım 11, 2 resimden 1. HTC Trophy Volume Buttons Replacement: adım 11, 2 resimden 2.
    • Desolder the volume buttons off of the motherboard.
    • Be careful not to overheat other components on the motherboard.
    • For more information on soldering and desoldering connections, please read the How to Solder and Desolder Connections guide.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 82
