Ana içeriğe geç
HTC Vive Cosmos Daughterboard Replacement
Neye ihtiyacın var
  1. HTC Vive Cosmos Daughterboard Replacement, Remove the facerest: adım 1, 3 resimden 1. HTC Vive Cosmos Daughterboard Replacement, Remove the facerest: adım 1, 3 resimden 2. HTC Vive Cosmos Daughterboard Replacement, Remove the facerest: adım 1, 3 resimden 3.
    • Pull the bottom of the facerest straight away from the Vive Cosmos to unclip it from the Vive.
    • With the bottom unclipped, pull the top of the facerest away from the Vive to remove it.
  2. HTC Vive Cosmos Daughterboard Replacement, Release the faceplate switch: adım 2, 2 resimden 1. HTC Vive Cosmos Daughterboard Replacement, Release the faceplate switch: adım 2, 2 resimden 2.
    • Use your finger to push the sliding faceplate release switch, sitting to the left of the lenses, toward the bottom of the Vive.
  3. HTC Vive Cosmos Daughterboard Replacement, Remove the faceplate: adım 3, 2 resimden 1. HTC Vive Cosmos Daughterboard Replacement, Remove the faceplate: adım 3, 2 resimden 2.
    • While holding the switch in the bottom position, pull the faceplate straight up and away from the front of the Vive.
    • Remove the faceplate.
  4. HTC Vive Cosmos Daughterboard Replacement, Unscrew the focus knob: adım 4, 1 resimden 1.
    • Use a T5 Torx driver to remove the 4.1 mm long screw securing the focus knob.
  5. HTC Vive Cosmos Daughterboard Replacement, Remove the focus knob: adım 5, 2 resimden 1. HTC Vive Cosmos Daughterboard Replacement, Remove the focus knob: adım 5, 2 resimden 2.
    • Slide the focus knob out of the plastic housing, off of the focus rod, and remove it.
  6. HTC Vive Cosmos Daughterboard Replacement, Unplug the audio connector: adım 6, 3 resimden 1. HTC Vive Cosmos Daughterboard Replacement, Unplug the audio connector: adım 6, 3 resimden 2. HTC Vive Cosmos Daughterboard Replacement, Unplug the audio connector: adım 6, 3 resimden 3.
    • Twist the 3.5 mm audio connector counter-clockwise slightly and slide its cable out from under the plastic retaining clip.
    • Lift the audio connector straight up to unplug it.
  7. HTC Vive Cosmos Daughterboard Replacement, Unscrew the LCD and motherboard assembly: adım 7, 1 resimden 1.
    • Use a T5 Torx driver to remove the three 4.1 mm long screws securing the LCD and motherboard assembly.
  8. HTC Vive Cosmos Daughterboard Replacement: adım 8, 2 resimden 1. HTC Vive Cosmos Daughterboard Replacement: adım 8, 2 resimden 2.
    • Gently peel up the stickers on either side of the front of the Vive. If possible, keep the stickers intact and reuse them.
  9. HTC Vive Cosmos Daughterboard Replacement: adım 9, 1 resimden 1.
    • Use a T5 Torx driver to unscrew the screws securing the upper component cover and the LCD and motherboard assembly:
    • Sixteen 4.1 mm long screws
    • One captive screw
    • This screw is covered by a sticker. Poke your driver through the sticker to access the screw.
    • Two 4.1 mm long screws
    • These screws are covered by stickers. Poke your driver through the stickers to access the screws.
  10. HTC Vive Cosmos Daughterboard Replacement, Remove the microphone: adım 10, 1 resimden 1.
    • Remove the microphone cover from the bottom edge of the headset.
  11. HTC Vive Cosmos Daughterboard Replacement, Separate the microphone adhesive: adım 11, 2 resimden 1. HTC Vive Cosmos Daughterboard Replacement, Separate the microphone adhesive: adım 11, 2 resimden 2.
    • Slide an opening pick under the microphone to separate the adhesive securing it to the Vive.
    • If this is difficult, use a heated iOpener, hair dryer, or heat gun to apply heat to adhesive.
  12. HTC Vive Cosmos Daughterboard Replacement, Remove the upper component cover: adım 12, 3 resimden 1. HTC Vive Cosmos Daughterboard Replacement, Remove the upper component cover: adım 12, 3 resimden 2. HTC Vive Cosmos Daughterboard Replacement, Remove the upper component cover: adım 12, 3 resimden 3.
    • Angle the bottom end of the upper component cover away from the front of the Vive.
    • Pull the upper component cover away from the front of the Vive and remove it.
  13. HTC Vive Cosmos Daughterboard Replacement, Remove the camera connector covers: adım 13, 3 resimden 1. HTC Vive Cosmos Daughterboard Replacement, Remove the camera connector covers: adım 13, 3 resimden 2. HTC Vive Cosmos Daughterboard Replacement, Remove the camera connector covers: adım 13, 3 resimden 3.
    • Slide the camera connector covers on either side of the LCD and motherboard assembly away from the center off of the assembly and remove them.
  14. HTC Vive Cosmos Daughterboard Replacement, Disconnect the cameras: adım 14, 3 resimden 1. HTC Vive Cosmos Daughterboard Replacement, Disconnect the cameras: adım 14, 3 resimden 2. HTC Vive Cosmos Daughterboard Replacement, Disconnect the cameras: adım 14, 3 resimden 3.
    • Peel the tape over the right camera connector back enough to access the camera's ZIF connector underneath.
    • Repeat the same process to peel back the tape over the left camera ZIF connector.
  15. HTC Vive Cosmos Daughterboard Replacement: adım 15, 3 resimden 1. HTC Vive Cosmos Daughterboard Replacement: adım 15, 3 resimden 2. HTC Vive Cosmos Daughterboard Replacement: adım 15, 3 resimden 3.
    • Use the point of a spudger to flip up the small locking flap securing the right camera cable ZIF connector.
    • Carefully slide the camera connector cable straight out of its socket on the motherboard.
  16. HTC Vive Cosmos Daughterboard Replacement: adım 16, 2 resimden 1. HTC Vive Cosmos Daughterboard Replacement: adım 16, 2 resimden 2.
    • Use the point of a spudger to flip up the small locking flap securing the left camera cable ZIF connector.
  17. HTC Vive Cosmos Daughterboard Replacement, Disconnect the microphone: adım 17, 1 resimden 1.
    • Peel the yellow tape off of the microphone connector.
  18. HTC Vive Cosmos Daughterboard Replacement: adım 18, 2 resimden 1. HTC Vive Cosmos Daughterboard Replacement: adım 18, 2 resimden 2.
    • Use the point of a spudger to flip up the small locking flap securing the microphone cable ZIF connector.
  19. HTC Vive Cosmos Daughterboard Replacement: adım 19, 3 resimden 1. HTC Vive Cosmos Daughterboard Replacement: adım 19, 3 resimden 2. HTC Vive Cosmos Daughterboard Replacement: adım 19, 3 resimden 3.
    • Carefully slide the microphone connector cable straight out of its socket on the motherboard.
    • With the cable out of its socket, slide the cable toward the bottom of the Vive and out of its clip on the LCD and motherboard assembly.
    • Take care not to crease or tear the cable while you're moving it.
  20. HTC Vive Cosmos Daughterboard Replacement, Remove the LCD and motherboard assembly: adım 20, 2 resimden 1. HTC Vive Cosmos Daughterboard Replacement, Remove the LCD and motherboard assembly: adım 20, 2 resimden 2.
    • Lift the LCD and motherboard assembly out of the headset.
    • The assembly is secured by clips around the edges. It may help to release the clips using a thin plastic tool, like an opening tool or a spudger.
  21. HTC Vive Cosmos Daughterboard Replacement, Disconnect the LCD panels: adım 21, 1 resimden 1.
    • Use a T5 Torx driver to remove the four 2.9 mm long screws securing the LCD connectors.
  22. HTC Vive Cosmos Daughterboard Replacement: adım 22, 3 resimden 1. HTC Vive Cosmos Daughterboard Replacement: adım 22, 3 resimden 2. HTC Vive Cosmos Daughterboard Replacement: adım 22, 3 resimden 3.
    • Use the flat end of a spudger to pry the LCD connectors straight up and out of their sockets on the daughterboard.
  23. HTC Vive Cosmos Daughterboard Replacement, Disconnect the interconnect cable: adım 23, 1 resimden 1.
    • Peel the tape over the motherboard interconnect cable back far enough to access the cable connector.
  24. HTC Vive Cosmos Daughterboard Replacement: adım 24, 3 resimden 1. HTC Vive Cosmos Daughterboard Replacement: adım 24, 3 resimden 2. HTC Vive Cosmos Daughterboard Replacement: adım 24, 3 resimden 3.
    • Use the flat end of a spudger to flip up the locking flap securing the interconnect cable ZIF connector.
    • Carefully slide the interconnect cable straight out of its socket.
  25. HTC Vive Cosmos Daughterboard Replacement, Unscrew the daughterboard: adım 25, 1 resimden 1.
    • Use a T5 Torx driver to remove the six 4.1 mm long screws securing the daughterboard.
  26. HTC Vive Cosmos Daughterboard Replacement: adım 26, 2 resimden 1. HTC Vive Cosmos Daughterboard Replacement: adım 26, 2 resimden 2.
    • Do not remove the daughterboard yet. It is still connected to the motherboard.
    • Gently hinge the daughterboard up to access the underside.
  27. HTC Vive Cosmos Daughterboard Replacement, Disconnect the second interconnect cable: adım 27, 1 resimden 1.
    • Peel the tape over the second motherboard interconnect cable back far enough to access the cable connector.
  28. HTC Vive Cosmos Daughterboard Replacement: adım 28, 3 resimden 1. HTC Vive Cosmos Daughterboard Replacement: adım 28, 3 resimden 2. HTC Vive Cosmos Daughterboard Replacement: adım 28, 3 resimden 3.
    • Use the flat end of a spudger to flip up the locking flap securing the second interconnect cable ZIF connector.
    • Carefully slide the second interconnect cable straight out of its socket.
    • Remove the daughterboard from the LCD and motherboard assembly.
  29. HTC Vive Cosmos Daughterboard Replacement, Remove the faceplate connector and cable: adım 29, 1 resimden 1.
    • Peel the tape over the faceplate connector cable back far enough to access the ZIF connector on the daughterboard.
  30. HTC Vive Cosmos Daughterboard Replacement: adım 30, 3 resimden 1. HTC Vive Cosmos Daughterboard Replacement: adım 30, 3 resimden 2. HTC Vive Cosmos Daughterboard Replacement: adım 30, 3 resimden 3.
    • Use the flat end of a spudger to flip up the small locking flap securing the faceplate cable ZIF connector.
    • Carefully slide the faceplate connector cable straight out of its socket on the daughterboard.
  31. HTC Vive Cosmos Daughterboard Replacement, Remove the daughterboard: adım 31, 1 resimden 1.
    • Only the daughterboard remains.
Sonuç
Adam O'Camb
197.105 İtibar
416 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 10
Her zaman: 548
