Ana içeriğe geç
HTC Vive Facerest Replacement
Neye ihtiyacın var
  1. HTC Vive Facerest Replacement, Unscrew the head strap mounts: adım 1, 2 resimden 1. HTC Vive Facerest Replacement, Unscrew the head strap mounts: adım 1, 2 resimden 2.
    • Be sure to power down and disconnect your Vive before beginning.
    • Use a T5 Torx driver to remove the two 12 mm-long screws securing the head strap mounts on either side of the headset.
    • For some devices, a T6 Torx driver may work better.
    • The mounts may fall off when the screws are removed, so be careful not to lose any parts.
  2. HTC Vive Facerest Replacement, Remove the head strap mounts: adım 2, 3 resimden 1. HTC Vive Facerest Replacement, Remove the head strap mounts: adım 2, 3 resimden 2. HTC Vive Facerest Replacement, Remove the head strap mounts: adım 2, 3 resimden 3.
    • Remove both head strap mounts.
  3. HTC Vive Facerest Replacement, Remove the facerest: adım 3, 2 resimden 1. HTC Vive Facerest Replacement, Remove the facerest: adım 3, 2 resimden 2.
    • Slide the facerest straight away from the headset to remove it.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Adam O'Camb
209.768 İtibar
416 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 42
Her zaman: 2,481
