Ana içeriğe geç
HTC Vive Motherboard Replacement
Neye ihtiyacın var
    1. HTC Vive Motherboard Replacement, Open the cable compartment: adım 1, 3 resimden 1. HTC Vive Motherboard Replacement, Open the cable compartment: adım 1, 3 resimden 2. HTC Vive Motherboard Replacement, Open the cable compartment: adım 1, 3 resimden 3.
      • Be sure to power down and disconnect your Vive before beginning.
      • Place a finger on the top edge of the compartment cover assembly and slide the assembly toward the front of the Vive until it comes loose from the headset.
      • Lift the cover away from the headset and slide it up the cables until it's out of the way.
      FixBot'a Sor
      Yorum Ekle
    2. HTC Vive Motherboard Replacement, Unplug the HDMI cable: adım 2, 2 resimden 1. HTC Vive Motherboard Replacement, Unplug the HDMI cable: adım 2, 2 resimden 2.
      • Lift the HDMI cable straight up to unplug it from the headset.
      FixBot'a Sor
      Yorum Ekle
    3. HTC Vive Motherboard Replacement, Unplug the remaining cables: adım 3, 3 resimden 1. HTC Vive Motherboard Replacement, Unplug the remaining cables: adım 3, 3 resimden 2. HTC Vive Motherboard Replacement, Unplug the remaining cables: adım 3, 3 resimden 3.
      • Repeat the lifting and unplugging process with the remaining USB, power, and audio cables.
      FixBot'a Sor
      Yorum Ekle
    1. HTC Vive Motherboard Replacement, Unscrew the head strap mounts: adım 4, 2 resimden 1. HTC Vive Motherboard Replacement, Unscrew the head strap mounts: adım 4, 2 resimden 2.
      • Use a T5 Torx driver to remove the two 12 mm-long screws securing the head strap mounts on either side of the headset.
      • For some devices, a T6 Torx driver may work better.
      • The mounts may fall off when the screws are removed, so be careful not to lose any parts.
      FixBot'a Sor
      Yorum Ekle
    2. HTC Vive Motherboard Replacement, Remove the head strap mounts: adım 5, 3 resimden 1. HTC Vive Motherboard Replacement, Remove the head strap mounts: adım 5, 3 resimden 2. HTC Vive Motherboard Replacement, Remove the head strap mounts: adım 5, 3 resimden 3.
      • Remove both head strap mounts.
      FixBot'a Sor
      Yorum Ekle
    3. HTC Vive Motherboard Replacement, Remove the facerest: adım 6, 2 resimden 1. HTC Vive Motherboard Replacement, Remove the facerest: adım 6, 2 resimden 2.
      • Slide the facerest straight away from the headset to remove it.
      FixBot'a Sor
      Yorum Ekle
    1. HTC Vive Motherboard Replacement, Unscrew the outer shell: adım 7, 3 resimden 1. HTC Vive Motherboard Replacement, Unscrew the outer shell: adım 7, 3 resimden 2. HTC Vive Motherboard Replacement, Unscrew the outer shell: adım 7, 3 resimden 3.
      Bu adımda kullanılan alet:
      • Use tweezers to remove the small stickers over the four screws securing the outer shell.
      • Use a T5 Torx driver to remove the four 3.4 mm-long screws securing the outer shell.
      FixBot'a Sor
      Yorum Ekle
    2. HTC Vive Motherboard Replacement, Remove the outer shell: adım 8, 3 resimden 1. HTC Vive Motherboard Replacement, Remove the outer shell: adım 8, 3 resimden 2. HTC Vive Motherboard Replacement, Remove the outer shell: adım 8, 3 resimden 3.
      • Grasp the top edge of the right half of the outer shell, behind the component cover and near the seam in the center. Pull it to the right and upward, away from the headset to release the clip securing that part of the shell.
      FixBot'a Sor
      Yorum Ekle
    3. HTC Vive Motherboard Replacement: adım 9, 2 resimden 1. HTC Vive Motherboard Replacement: adım 9, 2 resimden 2.
      • Grasp the right half the outer shell and pull it to the right and toward the front of the headset in a twisting motion until you feel the clips on the front of the cover release.
      FixBot'a Sor
      Yorum Ekle
    4. HTC Vive Motherboard Replacement: adım 10, 2 resimden 1. HTC Vive Motherboard Replacement: adım 10, 2 resimden 2.
      • Slide the right side of the outer shell to the right and off of the headset.
      FixBot'a Sor
      Yorum Ekle
    5. HTC Vive Motherboard Replacement: adım 11, 2 resimden 1. HTC Vive Motherboard Replacement: adım 11, 2 resimden 2.
      • Repeat the last three steps for the left side of the outer shell and remove it.
      FixBot'a Sor
      Yorum Ekle
    1. HTC Vive Motherboard Replacement, Disconnect the sensor array cables: adım 12, 3 resimden 1. HTC Vive Motherboard Replacement, Disconnect the sensor array cables: adım 12, 3 resimden 2. HTC Vive Motherboard Replacement, Disconnect the sensor array cables: adım 12, 3 resimden 3.
      • Use tweezers to remove the clear tape over all four of the sensor array cable connectors.
      FixBot'a Sor
      Yorum Ekle
    2. HTC Vive Motherboard Replacement: adım 13, 3 resimden 1. HTC Vive Motherboard Replacement: adım 13, 3 resimden 2. HTC Vive Motherboard Replacement: adım 13, 3 resimden 3.
      • Use the pointed end of a spudger to flip up the small locking flap on one of the sensor array ZIF connectors.
      • Slide the cable straight out of its socket on the motherboard.
      FixBot'a Sor
      Yorum Ekle
    3. HTC Vive Motherboard Replacement: adım 14, 3 resimden 1. HTC Vive Motherboard Replacement: adım 14, 3 resimden 2. HTC Vive Motherboard Replacement: adım 14, 3 resimden 3.
      • Repeat the previous step for the remaining three sensor array cables to disconnect the remaining cables.
      FixBot'a Sor
      Yorum Ekle
    4. HTC Vive Motherboard Replacement: adım 15, 2 resimden 1. HTC Vive Motherboard Replacement: adım 15, 2 resimden 2.
      • Use tweezers or a spudger to pry up the camera cable cover and remove it.
      FixBot'a Sor
      Yorum Ekle
    5. HTC Vive Motherboard Replacement: adım 16, 2 resimden 1. HTC Vive Motherboard Replacement: adım 16, 2 resimden 2.
      • Use the flat end of a spudger to pry the camera cable connector straight up from its socket on the motherboard.
      FixBot'a Sor
      Yorum Ekle
    6. HTC Vive Motherboard Replacement, Unscrew the sensor array: adım 17, 1 resimden 1.
      • Use a PH000 driver to remove the five 3.9 mm screws securing the sensor array.
      FixBot'a Sor
      Yorum Ekle
    7. HTC Vive Motherboard Replacement: adım 18, 1 resimden 1.
      • Use a PH000 driver to remove the four 3.9 mm screws securing the sensor array.
      FixBot'a Sor
      Yorum Ekle
    8. HTC Vive Motherboard Replacement: adım 19, 2 resimden 1. HTC Vive Motherboard Replacement: adım 19, 2 resimden 2.
      Phillips #000 Screwdriver
      $5.49
      • You'll need a narrow, long-shaft driver to reach these screws.
      FixBot'a Sor
      Yorum Ekle
    9. HTC Vive Motherboard Replacement, Remove the sensor array: adım 20, 2 resimden 1. HTC Vive Motherboard Replacement, Remove the sensor array: adım 20, 2 resimden 2.
      • Lift the sensor array away from the headset to remove it.
      FixBot'a Sor
      Yorum Ekle
    1. HTC Vive Motherboard Replacement, Disconnect the motherboard: adım 21, 3 resimden 1. HTC Vive Motherboard Replacement, Disconnect the motherboard: adım 21, 3 resimden 2. HTC Vive Motherboard Replacement, Disconnect the motherboard: adım 21, 3 resimden 3.
      • Remove the tape covering the interconnect cable socket.
      • Use the point of a spudger to flip up the small locking flap on the cable socket.
      • Slide the interconnect cable straight out of its socket on the motherboard.
      FixBot'a Sor
      Yorum Ekle
    2. HTC Vive Motherboard Replacement: adım 22, 3 resimden 1. HTC Vive Motherboard Replacement: adım 22, 3 resimden 2. HTC Vive Motherboard Replacement: adım 22, 3 resimden 3.
      • Remove the tape covering the left OLED cable socket.
      • Slide the left OLED cable straight out of its socket on the motherboard.
      FixBot'a Sor
      Yorum Ekle
    3. HTC Vive Motherboard Replacement: adım 23, 3 resimden 1. HTC Vive Motherboard Replacement: adım 23, 3 resimden 2. HTC Vive Motherboard Replacement: adım 23, 3 resimden 3.
      • Remove the tape covering the right OLED cable socket.
      • Slide the right OLED cable straight out of its socket on the motherboard.
      FixBot'a Sor
      Yorum Ekle
    4. HTC Vive Motherboard Replacement: adım 24, 2 resimden 1. HTC Vive Motherboard Replacement: adım 24, 2 resimden 2.
      • Use a pair tweezers to slightly twist the interconnect cable and press it down until the tabs on either side of the cable clear the hole in the motherboard.
      • During reassembly, make sure to thread the interconnect cable through its slot in the motherboard.
      FixBot'a Sor
      Yorum Ekle
    5. HTC Vive Motherboard Replacement, Remove the motherboard: adım 25, 3 resimden 1. HTC Vive Motherboard Replacement, Remove the motherboard: adım 25, 3 resimden 2. HTC Vive Motherboard Replacement, Remove the motherboard: adım 25, 3 resimden 3.
      • Press the non-port-end of the motherboard toward the top of headset while hinging it away from the midframe to free it from the clips securing that end.
      • Slide the motherboard toward the bottom of the headset, over the clips, to remove it.
      • Take care not to snag any cables during removal.
      FixBot'a Sor
      Yorum Ekle
Sonuç
9 farklı kişi bu kılavuzu tamamladı.
Adam O'Camb
224.382 İtibar
416 adet Kılavuz yazıldı
4Kılavuz Yorumları
Any recommendations as to where to find a motherboard for the vive? Having trouble getting google to stop recommending motherboards that support vr.
Devin Parker - Yanıt Paylaş
You may (or may not) have luck trying to grab Vives with different broken parts off of eBay.
Gabriel Medina-Kim - Yanıt Paylaş
is that really the only way?
Gus - Yanıt Paylaş
Anyone know where to get a replacement vive motherboard? Even if it’s from china
Mott Hubris - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 11
Son 30 gün: 47
Her zaman: 8,109
