Giriş
Follow this guide to replace the facerest in your HTC Vive Pro.
Power off and unplug your headset before you begin your repair.
Neye ihtiyacın var
Remove the All-In-One Cable from the cable guides along the left side of the head strap.
Peel off both front side foam pads to uncover the speaker wires.
Insert the pointed end of your spudger behind the square rubber spacer next to each headphone screw.
Gently pry the rubber spacers out of the head strap.
Use the pointed end of your spudger to pry up and disconnect both the left and right headphone speaker wires.
Use a T6 Torx screwdriver to remove the two 12.1 mm screws (one on each side) securing the head strap to the headset.
Use a T5 Torx screwdriver to remove the following screws securing the head strap to the headset:
Four 3.9 mm screws (two on each side)
Two 4.1 mm screws (one on each side)
Partially separate the facerest and the sensor array to access the daughterboard.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Valve Index Answers community for help.
Bir başkası bu kılavuzu tamamladı.
