Ana içeriğe geç
HTC Vive Pro Sensor Array Replacement
Neye ihtiyacın var
  1. HTC Vive Pro Sensor Array Replacement, Reposition the head strap: adım 1, 2 resimden 1. HTC Vive Pro Sensor Array Replacement, Reposition the head strap: adım 1, 2 resimden 2.
    • Rotate the head strap forward as far as it will go.
    FixBot'a Sor
    Yorum Ekle
  2. HTC Vive Pro Sensor Array Replacement, Unplug the All-In-One Cable: adım 2, 2 resimden 1. HTC Vive Pro Sensor Array Replacement, Unplug the All-In-One Cable: adım 2, 2 resimden 2.
    • Unplug the All-In-One Cable from your headset.
    FixBot'a Sor
    Yorum Ekle
  3. HTC Vive Pro Sensor Array Replacement, Remove the All-In-One Cable: adım 3, 3 resimden 1. HTC Vive Pro Sensor Array Replacement, Remove the All-In-One Cable: adım 3, 3 resimden 2. HTC Vive Pro Sensor Array Replacement, Remove the All-In-One Cable: adım 3, 3 resimden 3.
    • Remove the All-In-One Cable from the cable guides along the left side of the head strap.
    • During reassembly, connect the All-In-One Cable to the headset before routing it through the cable guides. This will ensure it has the right amount of slack.
    FixBot'a Sor
    Yorum Ekle
  4. HTC Vive Pro Sensor Array Replacement, Remove the top strap: adım 4, 2 resimden 1. HTC Vive Pro Sensor Array Replacement, Remove the top strap: adım 4, 2 resimden 2.
    • Separate the top strap from itself where the Velcro secures it.
    FixBot'a Sor
    Yorum Ekle
  5. HTC Vive Pro Sensor Array Replacement: adım 5, 3 resimden 1. HTC Vive Pro Sensor Array Replacement: adım 5, 3 resimden 2. HTC Vive Pro Sensor Array Replacement: adım 5, 3 resimden 3.
    • Peel back the Velcro securing the rear of the top strap.
    • Feed the top strap out through the head strap to partially remove it.
    FixBot'a Sor
    Yorum Ekle
  6. HTC Vive Pro Sensor Array Replacement: adım 6, 3 resimden 1. HTC Vive Pro Sensor Array Replacement: adım 6, 3 resimden 2. HTC Vive Pro Sensor Array Replacement: adım 6, 3 resimden 3.
    • Feed the top strap through the clip near the front of headset to fully remove it.
    FixBot'a Sor
    Yorum Ekle
  7. HTC Vive Pro Sensor Array Replacement, Remove the front side foam pads: adım 7, 3 resimden 1. HTC Vive Pro Sensor Array Replacement, Remove the front side foam pads: adım 7, 3 resimden 2. HTC Vive Pro Sensor Array Replacement, Remove the front side foam pads: adım 7, 3 resimden 3.
    • Peel off both front side foam pads to uncover the speaker wires.
    FixBot'a Sor
    Yorum Ekle
  8. HTC Vive Pro Sensor Array Replacement, Remove the two rubber spacers: adım 8, 3 resimden 1. HTC Vive Pro Sensor Array Replacement, Remove the two rubber spacers: adım 8, 3 resimden 2. HTC Vive Pro Sensor Array Replacement, Remove the two rubber spacers: adım 8, 3 resimden 3.
    • Use the point of your spudger to pry out the two rubber spacers next to the headphone screws.
    • Be careful not to accidentally pry any of the speaker wires under the rubber spacer.
    FixBot'a Sor
    Yorum Ekle
  9. HTC Vive Pro Sensor Array Replacement, Disconnect the speaker wires: adım 9, 3 resimden 1. HTC Vive Pro Sensor Array Replacement, Disconnect the speaker wires: adım 9, 3 resimden 2. HTC Vive Pro Sensor Array Replacement, Disconnect the speaker wires: adım 9, 3 resimden 3.
    • Use the point of your spudger to pry up and disconnect both the left and right headphone speaker wires.
    FixBot'a Sor
    Yorum Ekle
  10. HTC Vive Pro Sensor Array Replacement, Remove the head strap: adım 10, 2 resimden 1. HTC Vive Pro Sensor Array Replacement, Remove the head strap: adım 10, 2 resimden 2.
    • Use a T6 Torx screwdriver to remove the two 12.1 mm screws (one on each side) securing the head strap to the headset.
    • Use a T5 Torx screwdriver to remove the following screws securing the head strap to the headset:
    • Four 3.9 mm screws (two on each side)
    • Two 4.1 mm screws (one on each side)
    FixBot'a Sor
    Yorum Ekle
  11. HTC Vive Pro Sensor Array Replacement: adım 11, 1 resimden 1.
    • Remove the two plastic spacers underneath the previously removed Torx T6 screw.
    FixBot'a Sor
    Yorum Ekle
  12. HTC Vive Pro Sensor Array Replacement: adım 12, 3 resimden 1. HTC Vive Pro Sensor Array Replacement: adım 12, 3 resimden 2. HTC Vive Pro Sensor Array Replacement: adım 12, 3 resimden 3.
    • Thread the headphone speaker wires out through both ends of the head strap.
    FixBot'a Sor
    Yorum Ekle
  13. HTC Vive Pro Sensor Array Replacement, Remove the outer shell: adım 13, 3 resimden 1. HTC Vive Pro Sensor Array Replacement, Remove the outer shell: adım 13, 3 resimden 2. HTC Vive Pro Sensor Array Replacement, Remove the outer shell: adım 13, 3 resimden 3.
    • The four screws securing the outer shell are covered with black stickers. If the stickers are difficult to remove, simply press your T6 Torx driver through them.
    FixBot'a Sor
    Yorum Ekle
  14. HTC Vive Pro Sensor Array Replacement: adım 14, 2 resimden 1. HTC Vive Pro Sensor Array Replacement: adım 14, 2 resimden 2.
    • Use a T6 Torx screwdriver to remove the four 3.9 mm screws (two on top, two on bottom) securing the outer shell to the headset.
    FixBot'a Sor
    Yorum Ekle
  15. HTC Vive Pro Sensor Array Replacement: adım 15, 3 resimden 1. HTC Vive Pro Sensor Array Replacement: adım 15, 3 resimden 2. HTC Vive Pro Sensor Array Replacement: adım 15, 3 resimden 3.
    • Insert an opening pick into the seam between the two halves of the outer shell.
    • Slide the opening pick through the seam to dislodge the clips securing it to the headset.
    • Only insert the opening pick as far as necessary. There are ribbon cables underneath the outer shell.
    FixBot'a Sor
    Yorum Ekle
  16. HTC Vive Pro Sensor Array Replacement: adım 16, 3 resimden 1. HTC Vive Pro Sensor Array Replacement: adım 16, 3 resimden 2. HTC Vive Pro Sensor Array Replacement: adım 16, 3 resimden 3.
    • Continue sliding the opening pick through each seam until all clips have been dislodged.
    FixBot'a Sor
    Yorum Ekle
  17. HTC Vive Pro Sensor Array Replacement: adım 17, 3 resimden 1. HTC Vive Pro Sensor Array Replacement: adım 17, 3 resimden 2. HTC Vive Pro Sensor Array Replacement: adım 17, 3 resimden 3.
    • Carefully slide each half of the outer shell off of the sensor array.
    • Be careful not to snag any of the ribbon cables underneath.
    FixBot'a Sor
    Yorum Ekle
  18. HTC Vive Pro Sensor Array Replacement, Remove the face rest cushion: adım 18, 3 resimden 1. HTC Vive Pro Sensor Array Replacement, Remove the face rest cushion: adım 18, 3 resimden 2. HTC Vive Pro Sensor Array Replacement, Remove the face rest cushion: adım 18, 3 resimden 3.
    • Use your fingers to gently peel the face rest cushion off of the headset.
    FixBot'a Sor
    Yorum Ekle
  19. HTC Vive Pro Sensor Array Replacement, Remove the facerest: adım 19, 2 resimden 1. HTC Vive Pro Sensor Array Replacement, Remove the facerest: adım 19, 2 resimden 2.
    • Partially separate the facerest and the sensor array to access the daughterboard.
    FixBot'a Sor
    Yorum Ekle
  20. HTC Vive Pro Sensor Array Replacement: adım 20, 2 resimden 1. HTC Vive Pro Sensor Array Replacement: adım 20, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Use a pair of tweezers to remove the Kapton tape covering the white and purple wires on the daughterboard.
    FixBot'a Sor
    Yorum Ekle
  21. HTC Vive Pro Sensor Array Replacement: adım 21, 3 resimden 1. HTC Vive Pro Sensor Array Replacement: adım 21, 3 resimden 2. HTC Vive Pro Sensor Array Replacement: adım 21, 3 resimden 3.
    • Use the pointed end of a spudger to pry up and disconnect the purple and white wires from the daughterboard.
    • Use caution when disconnecting these wires. If you pry up too hard, they may pull out of the connector.
    FixBot'a Sor
    Yorum Ekle
  22. HTC Vive Pro Sensor Array Replacement: adım 22, 2 resimden 1. HTC Vive Pro Sensor Array Replacement: adım 22, 2 resimden 2.
    • Slide the facerest out of the front assembly.
    FixBot'a Sor
    Yorum Ekle
  23. HTC Vive Pro Sensor Array Replacement, Remove the sensor array: adım 23, 2 resimden 1. HTC Vive Pro Sensor Array Replacement, Remove the sensor array: adım 23, 2 resimden 2.
    • Use a pair of tweezers to remove the Kapton tape covering the ZIF connector on the daughterboard.
    FixBot'a Sor
    Yorum Ekle
  24. HTC Vive Pro Sensor Array Replacement: adım 24, 3 resimden 1. HTC Vive Pro Sensor Array Replacement: adım 24, 3 resimden 2. HTC Vive Pro Sensor Array Replacement: adım 24, 3 resimden 3.
    • Use the pointed end of a spudger to flip up the locking flap on the daughterboard ZIF connector.
    • Use a pair of tweezers to slide the ribbon cable out of its socket.
    FixBot'a Sor
    Yorum Ekle
  25. HTC Vive Pro Sensor Array Replacement: adım 25, 2 resimden 1. HTC Vive Pro Sensor Array Replacement: adım 25, 2 resimden 2.
    • Use a pair of tweezers to peel back the grey tape covering the ZIF connector on the motherboard underneath the sensor array.
    FixBot'a Sor
    Yorum Ekle
  26. HTC Vive Pro Sensor Array Replacement: adım 26, 3 resimden 1. HTC Vive Pro Sensor Array Replacement: adım 26, 3 resimden 2. HTC Vive Pro Sensor Array Replacement: adım 26, 3 resimden 3.
    • Use the flat end of your spudger to flip up the locking flap for the ZIF connector on the motherboard.
    • Use the pointed end of your spudger to disconnect the ribbon cable from the motherboard.
    FixBot'a Sor
    Yorum Ekle
  27. HTC Vive Pro Sensor Array Replacement: adım 27, 2 resimden 1. HTC Vive Pro Sensor Array Replacement: adım 27, 2 resimden 2.
    • Use a T5 Torx screwdriver to remove the four 3.0 mm silver screws securing the sensor array to the lens and OLED assembly.
    • Use a T6 Torx screwdriver to remove the four black 3.8 mm screws securing the sensor array.
    FixBot'a Sor
    Yorum Ekle
  28. HTC Vive Pro Sensor Array Replacement: adım 28, 2 resimden 1. HTC Vive Pro Sensor Array Replacement: adım 28, 2 resimden 2.
    • Lift the sensor array straight up off of the lens and OLED assembly.
    FixBot'a Sor
    Yorum Ekle
  29. HTC Vive Pro Sensor Array Replacement, Disconnect the motherboard from the sensor array: adım 29, 3 resimden 1. HTC Vive Pro Sensor Array Replacement, Disconnect the motherboard from the sensor array: adım 29, 3 resimden 2. HTC Vive Pro Sensor Array Replacement, Disconnect the motherboard from the sensor array: adım 29, 3 resimden 3.
    • Use a pair of tweezers or your fingers to remove the four pieces of Kapton tape covering the ZIF connectors.
    FixBot'a Sor
    Yorum Ekle
  30. HTC Vive Pro Sensor Array Replacement: adım 30, 3 resimden 1. HTC Vive Pro Sensor Array Replacement: adım 30, 3 resimden 2. HTC Vive Pro Sensor Array Replacement: adım 30, 3 resimden 3.
    • Use the flat end of your spudger to flip up the locking flap on a ZIF connector on the sensor array.
    • Use the pointed end of your spudger to disconnect the ribbon cable from its ZIF connector.
    • Repeat this procedure for all four of the ZIF connectors.
    FixBot'a Sor
    Yorum Ekle
  31. HTC Vive Pro Sensor Array Replacement: adım 31, 2 resimden 1. HTC Vive Pro Sensor Array Replacement: adım 31, 2 resimden 2.
    • Use a pair of tweezers to remove the Kapton tape covering the two ZIF connectors on the back of the motherboard.
    FixBot'a Sor
    Yorum Ekle
  32. HTC Vive Pro Sensor Array Replacement: adım 32, 3 resimden 1. HTC Vive Pro Sensor Array Replacement: adım 32, 3 resimden 2. HTC Vive Pro Sensor Array Replacement: adım 32, 3 resimden 3.
    • Use the point of your spudger to unlock the ZIF connector on the back of the motherboard.
    • Use the spudger, or your fingers, to slide the ribbon cable out of its socket.
    FixBot'a Sor
    Yorum Ekle
  33. HTC Vive Pro Sensor Array Replacement: adım 33, 3 resimden 1. HTC Vive Pro Sensor Array Replacement: adım 33, 3 resimden 2. HTC Vive Pro Sensor Array Replacement: adım 33, 3 resimden 3.
    FixBot'a Sor
    Yorum Ekle
  34. HTC Vive Pro Sensor Array Replacement: adım 34, 2 resimden 1. HTC Vive Pro Sensor Array Replacement: adım 34, 2 resimden 2.
    • Use a pair of tweezers to remove the Kapton tape covering the remaining ZIF connector on the back of the motherboard.
    FixBot'a Sor
    Yorum Ekle
  35. HTC Vive Pro Sensor Array Replacement: adım 35, 3 resimden 1. HTC Vive Pro Sensor Array Replacement: adım 35, 3 resimden 2. HTC Vive Pro Sensor Array Replacement: adım 35, 3 resimden 3.
    • Use the pointed end of your spudger to unlock the ZIF connector on the back of the motherboard.
    FixBot'a Sor
    Yorum Ekle
  36. HTC Vive Pro Sensor Array Replacement, Remove the motherboard: adım 36, 2 resimden 1. HTC Vive Pro Sensor Array Replacement, Remove the motherboard: adım 36, 2 resimden 2.
    • Reposition the long ribbon cable covering the back of the motherboard so it's out of the way.
    • Don't sharply crease or fold the ribbon cable.
    FixBot'a Sor
    Yorum Ekle
  37. HTC Vive Pro Sensor Array Replacement: adım 37, 2 resimden 1. HTC Vive Pro Sensor Array Replacement: adım 37, 2 resimden 2.
    • Use a T5 Torx screwdriver to remove the three 3.0 mm‑long screws securing the motherboard to the sensor array.
    FixBot'a Sor
    Yorum Ekle
  38. HTC Vive Pro Sensor Array Replacement: adım 38, 1 resimden 1.
    • Apply a heated iOpener to the back of the motherboard for one minute to soften the light adhesive securing it to the sensor array.
    FixBot'a Sor
    Yorum Ekle
  39. HTC Vive Pro Sensor Array Replacement: adım 39, 1 resimden 1.
    • Remove the motherboard from the sensor array.
    • There are several plastic clips lightly securing the perimeter of the motherboard to the sensor array.
    • During reassembly, don't forget to reinstall any Kapton tape that was removed during disassembly. This will prevent malfunction of the sensors.
    FixBot'a Sor
    Yorum Ekle
  40. HTC Vive Pro Sensor Array Replacement, Only the sensor array remains: adım 40, 1 resimden 1.
    • Only the sensor array remains.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Sam Omiotek
98.886 İtibar
290 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 5
Son 30 gün: 34
Her zaman: 982
