Ana içeriğe geç
HTC Vive Sensor Array Replacement
Neye ihtiyacın var
  1. HTC Vive Sensor Array Replacement, Open the cable compartment: adım 1, 3 resimden 1. HTC Vive Sensor Array Replacement, Open the cable compartment: adım 1, 3 resimden 2. HTC Vive Sensor Array Replacement, Open the cable compartment: adım 1, 3 resimden 3.
    • Be sure to power down and disconnect your Vive before beginning.
    • Place a finger on the top edge of the compartment cover assembly and slide the assembly toward the front of the Vive until it comes loose from the headset.
    • Lift the cover away from the headset and slide it up the cables until it's out of the way.
    FixBot'a Sor
    Yorum Ekle
  2. HTC Vive Sensor Array Replacement, Unplug the HDMI cable: adım 2, 2 resimden 1. HTC Vive Sensor Array Replacement, Unplug the HDMI cable: adım 2, 2 resimden 2.
    • Lift the HDMI cable straight up to unplug it from the headset.
    FixBot'a Sor
    Yorum Ekle
  3. HTC Vive Sensor Array Replacement, Unplug the remaining cables: adım 3, 3 resimden 1. HTC Vive Sensor Array Replacement, Unplug the remaining cables: adım 3, 3 resimden 2. HTC Vive Sensor Array Replacement, Unplug the remaining cables: adım 3, 3 resimden 3.
    • Repeat the lifting and unplugging process with the remaining USB, power, and audio cables.
    FixBot'a Sor
    Yorum Ekle
  4. HTC Vive Sensor Array Replacement, Unscrew the head strap mounts: adım 4, 2 resimden 1. HTC Vive Sensor Array Replacement, Unscrew the head strap mounts: adım 4, 2 resimden 2.
    • Use a T5 Torx driver to remove the two 12 mm-long screws securing the head strap mounts on either side of the headset.
    • For some devices, a T6 Torx driver may work better.
    • The mounts may fall off when the screws are removed, so be careful not to lose any parts.
    FixBot'a Sor
    Yorum Ekle
  5. HTC Vive Sensor Array Replacement, Remove the head strap mounts: adım 5, 3 resimden 1. HTC Vive Sensor Array Replacement, Remove the head strap mounts: adım 5, 3 resimden 2. HTC Vive Sensor Array Replacement, Remove the head strap mounts: adım 5, 3 resimden 3.
    • Remove both head strap mounts.
    FixBot'a Sor
    Yorum Ekle
  6. HTC Vive Sensor Array Replacement, Remove the facerest: adım 6, 2 resimden 1. HTC Vive Sensor Array Replacement, Remove the facerest: adım 6, 2 resimden 2.
    • Slide the facerest straight away from the headset to remove it.
    FixBot'a Sor
    Yorum Ekle
  7. HTC Vive Sensor Array Replacement, Unscrew the outer shell: adım 7, 3 resimden 1. HTC Vive Sensor Array Replacement, Unscrew the outer shell: adım 7, 3 resimden 2. HTC Vive Sensor Array Replacement, Unscrew the outer shell: adım 7, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Use tweezers to remove the small stickers over the four screws securing the outer shell.
    • Use a T5 Torx driver to remove the four 3.4 mm-long screws securing the outer shell.
    FixBot'a Sor
    Yorum Ekle
  8. HTC Vive Sensor Array Replacement, Remove the outer shell: adım 8, 3 resimden 1. HTC Vive Sensor Array Replacement, Remove the outer shell: adım 8, 3 resimden 2. HTC Vive Sensor Array Replacement, Remove the outer shell: adım 8, 3 resimden 3.
    • Grasp the top edge of the right half of the outer shell, behind the component cover and near the seam in the center. Pull it to the right and upward, away from the headset to release the clip securing that part of the shell.
    FixBot'a Sor
    Yorum Ekle
  9. HTC Vive Sensor Array Replacement: adım 9, 2 resimden 1. HTC Vive Sensor Array Replacement: adım 9, 2 resimden 2.
    • Grasp the right half the outer shell and pull it to the right and toward the front of the headset in a twisting motion until you feel the clips on the front of the cover release.
    FixBot'a Sor
    Yorum Ekle
  10. HTC Vive Sensor Array Replacement: adım 10, 2 resimden 1. HTC Vive Sensor Array Replacement: adım 10, 2 resimden 2.
    • Slide the right side of the outer shell to the right and off of the headset.
    FixBot'a Sor
    Yorum Ekle
  11. HTC Vive Sensor Array Replacement: adım 11, 2 resimden 1. HTC Vive Sensor Array Replacement: adım 11, 2 resimden 2.
    • Repeat the last three steps for the left side of the outer shell and remove it.
    FixBot'a Sor
    Yorum Ekle
  12. HTC Vive Sensor Array Replacement, Disconnect the sensor array cables: adım 12, 3 resimden 1. HTC Vive Sensor Array Replacement, Disconnect the sensor array cables: adım 12, 3 resimden 2. HTC Vive Sensor Array Replacement, Disconnect the sensor array cables: adım 12, 3 resimden 3.
    • Use tweezers to remove the clear tape over all four of the sensor array cable connectors.
    FixBot'a Sor
    Yorum Ekle
  13. HTC Vive Sensor Array Replacement: adım 13, 3 resimden 1. HTC Vive Sensor Array Replacement: adım 13, 3 resimden 2. HTC Vive Sensor Array Replacement: adım 13, 3 resimden 3.
    • Use the pointed end of a spudger to flip up the small locking flap on one of the sensor array ZIF connectors.
    • Slide the cable straight out of its socket on the motherboard.
    FixBot'a Sor
    Yorum Ekle
  14. HTC Vive Sensor Array Replacement: adım 14, 3 resimden 1. HTC Vive Sensor Array Replacement: adım 14, 3 resimden 2. HTC Vive Sensor Array Replacement: adım 14, 3 resimden 3.
    • Repeat the previous step for the remaining three sensor array cables to disconnect the remaining cables.
    FixBot'a Sor
    Yorum Ekle
  15. HTC Vive Sensor Array Replacement: adım 15, 2 resimden 1. HTC Vive Sensor Array Replacement: adım 15, 2 resimden 2.
    • Use tweezers or a spudger to pry up the camera cable cover and remove it.
    FixBot'a Sor
    Yorum Ekle
  16. HTC Vive Sensor Array Replacement: adım 16, 2 resimden 1. HTC Vive Sensor Array Replacement: adım 16, 2 resimden 2.
    • Use the flat end of a spudger to pry the camera cable connector straight up from its socket on the motherboard.
    FixBot'a Sor
    Yorum Ekle
  17. HTC Vive Sensor Array Replacement, Unscrew the sensor array: adım 17, 1 resimden 1.
    • Use a PH000 driver to remove the five 3.9 mm screws securing the sensor array.
    FixBot'a Sor
    Yorum Ekle
  18. HTC Vive Sensor Array Replacement: adım 18, 1 resimden 1.
    • Use a PH000 driver to remove the four 3.9 mm screws securing the sensor array.
    FixBot'a Sor
    Yorum Ekle
  19. HTC Vive Sensor Array Replacement: adım 19, 2 resimden 1. HTC Vive Sensor Array Replacement: adım 19, 2 resimden 2.
    Phillips #000 Screwdriver
    $5.49
    • You'll need a narrow, long-shaft driver to reach these screws.
    FixBot'a Sor
    Yorum Ekle
  20. HTC Vive Sensor Array Replacement, Remove the sensor array: adım 20, 2 resimden 1. HTC Vive Sensor Array Replacement, Remove the sensor array: adım 20, 2 resimden 2.
    • Lift the sensor array away from the headset to remove it.
    FixBot'a Sor
    Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Adam O'Camb
223.670 İtibar
416 adet Kılavuz yazıldı
2Kılavuz Yorumları
Herzlichen Dank für diese ausführliche Anleitung! Sie war sehr hilfreich und hat mir vermutlich eine Menge Zeit erspart!
Holger - Yanıt Paylaş
Buongiorno, dove trovate i pezzi di ricambio per questo tipo di maschera?
Grazie
sandro verta - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 39
Her zaman: 4,030
