Ana içeriğe geç
HTC Vive Head Strap Replacement
Neye ihtiyacın var
  1. HTC Vive Head Strap Replacement, Release the upper head strap: adım 1, 2 resimden 1. HTC Vive Head Strap Replacement, Release the upper head strap: adım 1, 2 resimden 2.
    • Be sure to power down and disconnect your Vive before beginning.
    • Pull the hook-and-loop (Velcro) closure at the top of the head strap apart to release the top of the head strap.
  2. HTC Vive Head Strap Replacement, Remove the upper head strap: adım 2, 2 resimden 1. HTC Vive Head Strap Replacement, Remove the upper head strap: adım 2, 2 resimden 2.
    • Slide the top part of the head strap through its metal loop on the headset to remove it.
  3. HTC Vive Head Strap Replacement, Remove the right side of the head strap: adım 3, 3 resimden 1. HTC Vive Head Strap Replacement, Remove the right side of the head strap: adım 3, 3 resimden 2. HTC Vive Head Strap Replacement, Remove the right side of the head strap: adım 3, 3 resimden 3.
    • Pull the hook-and-loop closure at the right side of the head strap apart to release the right side of the head strap.
    • Slide the right side of the head strap through its metal loop to remove it.
  4. HTC Vive Head Strap Replacement, Remove the left side of the head strap: adım 4, 3 resimden 1. HTC Vive Head Strap Replacement, Remove the left side of the head strap: adım 4, 3 resimden 2. HTC Vive Head Strap Replacement, Remove the left side of the head strap: adım 4, 3 resimden 3.
    • Pull the hook-and-loop closure at the left side of the head strap apart to release the left side of the head strap.
    • Slide the left side of the head strap through its metal loop to remove it.
  5. HTC Vive Head Strap Replacement, Remove the head strap: adım 5, 3 resimden 1. HTC Vive Head Strap Replacement, Remove the head strap: adım 5, 3 resimden 2. HTC Vive Head Strap Replacement, Remove the head strap: adım 5, 3 resimden 3.
    • Slide the head strap along the cable, away from the Vive.
    • When the head strap comes to the end of the cable, gently slide it over the plugs and remove it.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Adam O'Camb
196.299 İtibar
416 adet Kılavuz yazıldı
3 Yorum
What is the name of the Part that holds the strap and has VIVE written on it ? Can I order that part individually ?
Elias - Yanıt
You can find that part, as well as the center strap holder by searching on eBay for HTC Vive headset parts. I’ve attached a link here: https://www.ebay.com/itm/Genuine-HTC-VIV...
Ryan Stargell -
how to fix my headset strap on my vive i nead some help on it can you show me how.
GreggTHhompson - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 20
Son 30 gün: 61
Her zaman: 5,975
