Giriş
Use this guide to replace the proximity sensor in your HTC Vive XR Elite.
Neye ihtiyacın var
Press the release button on the right battery cradle temple slot.
Pull the battery cradle away from the right temple slot to disconnect it.
Grip the middle of the face cushion with your fingers and pull back to remove it.
Bu adımda kullanılan alet:Tweezers$4.99
Use tweezers to remove the six screw covers from the right temple.
Use a T5 Torx screwdriver to remove the six 4.9 mm‑long screws securing the two right temple halves.
Use a T5 Torx screwdriver to remove the two 3.5 mm‑long screws securing the right hinge cover.
Insert the flat end of a spudger in the gap between the right outer and inner hinge covers.
Slide the spudger along the gap to separate the clips securing the outer hinge cover.
Remove the outer hinge cover.
Insert the flat end of a spudger in the gap between the outer and inner temple.
Slide the spudger along the gap to separate the clips securing the outer temple.
Use tweezers to peel back the black tape covering one of the inner hinge cover screws.
Use a T5 Torx screwdriver to remove the two screws securing the inner hinge cover:
One 3.1 mm‑long screw
One 4.9 mm‑long screw
Rotate the inner hinge cover off its groove in the frame.
Thread the inner hinge cover off of the USB-C and speaker cables and remove it.
Use tweezers to remove the six screw covers from the left temple.
Use a T5 Torx screwdriver to remove the six 4.9 mm‑long screws securing the two left temple halves.
Use a T5 Torx screwdriver to remove the two 3.5 mm‑long screws securing the left hinge cover.
Insert the flat end of a spudger in the gap between the left outer and inner hinge covers.
One 3.5 mm‑long screw
Let the cover hang off its volume button cable for now.
Use a T5 Torx screwdriver to remove the 12 screws securing the face plate:
Six 3.5 mm‑long screws
Four 4.9 mm‑long screws
Two 6.5 mm‑long screws
There are two magnets at the top corners of the face plate. As you remove nearby screws, they might stick to them.
Insert the flat end of the spudger in the gap between the frame and the bottom right corner of the face cover.
Pry up with the spudger to release the clips securing the face cover.
Lift the face cover and rotate it over the top of the frame.
Lay the face cover face up before continuing.
Use a T5 Torx screwdriver to remove the two 3.3 mm‑long screws securing the proximity sensor cable.
Pull the two lenses outward so they're as far apart as possible.
Use a T5 Torx screwdriver to remove the four screws securing the lens assembly:
Three 4.9 mm‑long screws
One 3.3 mm‑long screw
Use tweezers to pull the left screw bracket of its post in the frame.
Repeat this process for the right bracket.
Lift the bottom of the lens assembly up to separate the bottom rails from their slots in the frame.
Pull the lens assembly upwards to separate the top rails from their slots in the frame.
Rotate the lens assembly towards the top of the frame so it sits upright with its cable connectors exposed.
Use a T5 Torx screwdriver to remove the four 3.4 mm‑long screws securing the lens assembly cables.
Use the flat end of a spudger to pry up and disconnect the lens assembly cable connector.
Repeat this procedure for the other connector.
In order for the lens assembly to rest in the frame properly, it needs to align with a peg in the IPD (interpupillary distance) slider.
Slide the top left rail into its slot.
Align the other rails.
Press the lens assembly into place, making sure to realign the center peg.
Use tweezers to peel off the black tape covering the proximity sensor connector.
Use the point of a spudger to lift up the locking flap on the proximity sensor ZIF connector.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for help.
