Ana içeriğe geç
Haiboxing 18859 Motor Replacement
Neye ihtiyacın var
  1. Haiboxing 18859 Motor Replacement, Battery: adım 1, 3 resimden 1. Haiboxing 18859 Motor Replacement, Battery: adım 1, 3 resimden 2. Haiboxing 18859 Motor Replacement, Battery: adım 1, 3 resimden 3.
    • Remove the 4 clips holding down the hard plastic shell of the RC car. Do this by pinching them with your thumb and index finger and pulling away.
    FixBot'a Sor
    Yorum Ekle
  2. Haiboxing 18859 Motor Replacement: adım 2, 1 resimden 1.
    • Lift the hard plastic shell off of the RC car.
    FixBot'a Sor
    Yorum Ekle
  3. Haiboxing 18859 Motor Replacement: adım 3, 3 resimden 1. Haiboxing 18859 Motor Replacement: adım 3, 3 resimden 2. Haiboxing 18859 Motor Replacement: adım 3, 3 resimden 3.
    • Disconnect the Lego-style battery connector by gripping either side and pulling them away from each other, slowly and consistently.
    FixBot'a Sor
    Yorum Ekle
  4. Haiboxing 18859 Motor Replacement: adım 4, 3 resimden 1. Haiboxing 18859 Motor Replacement: adım 4, 3 resimden 2. Haiboxing 18859 Motor Replacement: adım 4, 3 resimden 3.
    • Unfasten the Velcro strap that secures the battery.
    FixBot'a Sor
    Yorum Ekle
  5. Haiboxing 18859 Motor Replacement: adım 5, 2 resimden 1. Haiboxing 18859 Motor Replacement: adım 5, 2 resimden 2.
    • Remove the battery.
    FixBot'a Sor
    Yorum Ekle
  6. Haiboxing 18859 Motor Replacement, Motor: adım 6, 1 resimden 1.
    • Unplug the motor from the receiver.
    FixBot'a Sor
    Yorum Ekle
  7. Haiboxing 18859 Motor Replacement: adım 7, 1 resimden 1.
    • Peel back the warning tape covering the motor.
    FixBot'a Sor
    Yorum Ekle
  8. Haiboxing 18859 Motor Replacement: adım 8, 3 resimden 1. Haiboxing 18859 Motor Replacement: adım 8, 3 resimden 2. Haiboxing 18859 Motor Replacement: adım 8, 3 resimden 3.
    • Unscrew the 10 mm Phillips #0 screws holding down the motor. This includes the shaft attached down the middle.
    • Place the mounting screws where you won't lose them, such as in a plastic bag or container.
    FixBot'a Sor
    Yorum Ekle
  9. Haiboxing 18859 Motor Replacement: adım 9, 3 resimden 1. Haiboxing 18859 Motor Replacement: adım 9, 3 resimden 2. Haiboxing 18859 Motor Replacement: adım 9, 3 resimden 3.
    • Unscrew the 16 mm Phillips #1 screws at the rear of the Haiboxing.
    FixBot'a Sor
    Yorum Ekle
  10. Haiboxing 18859 Motor Replacement: adım 10, 2 resimden 1. Haiboxing 18859 Motor Replacement: adım 10, 2 resimden 2.
    • Remove the upwards facing rear-most 8 mm Phillips #1 screws.
    • Remove the trapezoid-shaped part.
    FixBot'a Sor
    Yorum Ekle
  11. Haiboxing 18859 Motor Replacement: adım 11, 1 resimden 1.
    • Lift out the motor and the shaft it is attached to.
    FixBot'a Sor
    Yorum Ekle
  12. Haiboxing 18859 Motor Replacement: adım 12, 1 resimden 1.
    • Remove the 6 mm Phillips #0 screw holding the motor to the black, plastic shaft.
    FixBot'a Sor
    Yorum Ekle
  13. Haiboxing 18859 Motor Replacement: adım 13, 2 resimden 1. Haiboxing 18859 Motor Replacement: adım 13, 2 resimden 2.
    • Flip over.
    • Detach the shaft from motor.
    FixBot'a Sor
    Yorum Ekle
  14. Haiboxing 18859 Motor Replacement: adım 14, 3 resimden 1. Haiboxing 18859 Motor Replacement: adım 14, 3 resimden 2. Haiboxing 18859 Motor Replacement: adım 14, 3 resimden 3.
    • Remove the remaining 6 mm Phillips #0 screw holding black, plastic washer in place.
    • Remove the black, plastic washer.
    • Remove the red, paper washer.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Ty.
219 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 6-3, Botvin Spring 2025 UMass Dartmouth, Team 6-3, Botvin Spring 2025 üyesi
UMASSD-BOTVIN-S25S6G3
3 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 15
Son 30 gün: 61
Her zaman: 656
