Ana içeriğe geç
Haiboxing 18859 Servo Replacement
Neye ihtiyacın var
  1. Haiboxing 18859 Servo Replacement, Battery: adım 1, 3 resimden 1. Haiboxing 18859 Servo Replacement, Battery: adım 1, 3 resimden 2. Haiboxing 18859 Servo Replacement, Battery: adım 1, 3 resimden 3.
    • Remove the 4 clips holding down the hard plastic shell of the RC car. Do this by pinching them with your thumb and index finger and pulling away.
    FixBot'a Sor
    Yorum Ekle
  2. Haiboxing 18859 Servo Replacement: adım 2, 1 resimden 1.
    • Lift the hard plastic shell off of the RC car.
    FixBot'a Sor
    Yorum Ekle
  3. Haiboxing 18859 Servo Replacement: adım 3, 3 resimden 1. Haiboxing 18859 Servo Replacement: adım 3, 3 resimden 2. Haiboxing 18859 Servo Replacement: adım 3, 3 resimden 3.
    • Disconnect the Lego-style battery connector by gripping either side and pulling them away from each other, slowly and consistently.
    FixBot'a Sor
    Yorum Ekle
  4. Haiboxing 18859 Servo Replacement: adım 4, 3 resimden 1. Haiboxing 18859 Servo Replacement: adım 4, 3 resimden 2. Haiboxing 18859 Servo Replacement: adım 4, 3 resimden 3.
    • Unfasten the Velcro strap that secures the battery.
    FixBot'a Sor
    Yorum Ekle
  5. Haiboxing 18859 Servo Replacement: adım 5, 2 resimden 1. Haiboxing 18859 Servo Replacement: adım 5, 2 resimden 2.
    • Remove the battery.
    FixBot'a Sor
    Yorum Ekle
  6. Haiboxing 18859 Servo Replacement, Receiver: adım 6, 3 resimden 1. Haiboxing 18859 Servo Replacement, Receiver: adım 6, 3 resimden 2. Haiboxing 18859 Servo Replacement, Receiver: adım 6, 3 resimden 3.
    • Disonnect all connectors attached to the red, plastic receiver.
    FixBot'a Sor
    Yorum Ekle
  7. Haiboxing 18859 Servo Replacement: adım 7, 1 resimden 1.
    • Remove the 8 mm Phillips #0 screw holding the front corner of the receiver down.
    • Remove the front corner piece.
    FixBot'a Sor
    Yorum Ekle
  8. Haiboxing 18859 Servo Replacement: adım 8, 3 resimden 1. Haiboxing 18859 Servo Replacement: adım 8, 3 resimden 2. Haiboxing 18859 Servo Replacement: adım 8, 3 resimden 3.
    • Remove the receiver.
    FixBot'a Sor
    Yorum Ekle
  9. Haiboxing 18859 Servo Replacement, Servo: adım 9, 2 resimden 1. Haiboxing 18859 Servo Replacement, Servo: adım 9, 2 resimden 2.
    • Remove the three 10 mm Phillips #0 screws holding the three-pointed plastic bracket in place.
    FixBot'a Sor
    Yorum Ekle
  10. Haiboxing 18859 Servo Replacement: adım 10, 1 resimden 1.
    • Remove the three-pointed plastic bracket.
    FixBot'a Sor
    Yorum Ekle
  11. Haiboxing 18859 Servo Replacement: adım 11, 1 resimden 1.
    • Remove the 10 mm Phillips #00 screw holding the white piece of the servo to the black plastic piece of the shaft.
    FixBot'a Sor
    Yorum Ekle
  12. Haiboxing 18859 Servo Replacement: adım 12, 1 resimden 1.
    • Remove the servo.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Kevin Hillmann
258 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 6-3, Botvin Spring 2025 UMass Dartmouth, Team 6-3, Botvin Spring 2025 üyesi
UMASSD-BOTVIN-S25S6G3
3 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 40
Her zaman: 375
