Ana içeriğe geç
Hair Scrunchie Elastic Replacement
Neye ihtiyacın var
  1. Hair Scrunchie Elastic Replacement, Hair Scrunchie Elastic: adım 1, 1 resimden 1.
    • There are two seams that hold the fabric outer tube of the scrunchie together. The long seam runs along the entire circumference of the tube. The short seam goes around just one part of the tube.
  2. Hair Scrunchie Elastic Replacement: adım 2, 2 resimden 1. Hair Scrunchie Elastic Replacement: adım 2, 2 resimden 2.
    • Locate the short seam and use the hem ripper to carefully cut through each stitch without damaging the fabric.
    • Do not cut through the stitches where the long seam intersect with he short seam.
  3. Hair Scrunchie Elastic Replacement: adım 3, 1 resimden 1.
    • Attach the elastic band to the end of a pencil with a piece of tape.
  4. Hair Scrunchie Elastic Replacement: adım 4, 2 resimden 1. Hair Scrunchie Elastic Replacement: adım 4, 2 resimden 2.
    • Insert the pencil tip into one end of the fabric tube.
    • As you push the pencil through, scrunch the fabric together until the tip comes out the other side.
  5. Hair Scrunchie Elastic Replacement: adım 5, 2 resimden 1. Hair Scrunchie Elastic Replacement: adım 5, 2 resimden 2.
    • Tie a secure knot with the newly replaced elastic.
  6. Hair Scrunchie Elastic Replacement: adım 6, 1 resimden 1.
    • Prepare your needle and thread by tying a knot at the end.
  7. Hair Scrunchie Elastic Replacement: adım 7, 1 resimden 1.
    • Insert the needle at the spot holding each end of the tube together.
  8. Hair Scrunchie Elastic Replacement: adım 8, 3 resimden 1. Hair Scrunchie Elastic Replacement: adım 8, 3 resimden 2. Hair Scrunchie Elastic Replacement: adım 8, 3 resimden 3.
    • Use the ladder stitch technique to sew each end of the tube back together.
    • Use this guide for assistance.
  9. Hair Scrunchie Elastic Replacement: adım 9, 3 resimden 1. Hair Scrunchie Elastic Replacement: adım 9, 3 resimden 2. Hair Scrunchie Elastic Replacement: adım 9, 3 resimden 3.
    • Tie a knot and use your finger to keep the knot close as close to the fabric as possible.
    • Repeat this process until the thread is secure.
  10. Hair Scrunchie Elastic Replacement: adım 10, 1 resimden 1.
    • Trim the thread as close to the knot as possible.
Sonuç
This is a simple and effective way to replace the elastic so that you can continue to use the hair accessory.
9 farklı kişi bu kılavuzu tamamladı.
Malena Hansen
239 İtibar
1 Kılavuz yazıldı
Ekip
UC Davis, Team S2-G2, Bender Fall 2018 UC Davis, Team S2-G2, Bender Fall 2018 üyesi
UCD-BENDER-F18S2G2
3 Üyeler
2 adet Kılavuz yazıldı
Bir Yorum
Amazing
Been looking for a way to fix my scrunchie
Thanks!
Mollytheduck1 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 21
Son 30 gün: 99
Her zaman: 23,466
