Giriş
Often the elastic interior of a scrunchie will break, while the outer cloth material remains intact. At this point, most people would discard their scrunchie as useless, contributing to the fashion waste stream. Buying a new scrunchie adds to pollution, depletion of natural resources, and unfair labor practices within the fast fashion industry. With the help of this guide, scrunchie users will be able to learn how to simply replace the inner elastic and repair their broken scrunchie. This guide is relatively simple, however, it requires the use of sharp objects, such as a needle and hem ripper.
Neye ihtiyacın var
There are two seams that hold the fabric outer tube of the scrunchie together. The long seam runs along the entire circumference of the tube. The short seam goes around just one part of the tube.
Use the ladder stitch technique to sew each end of the tube back together.
Use this guide for assistance.
This is a simple and effective way to replace the elastic so that you can continue to use the hair accessory.
9 farklı kişi bu kılavuzu tamamladı.
