Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
There are two seams that hold the fabric outer tube of the scrunchie together. The long seam runs along the entire circumference of the tube. The short seam goes around just one part of the tube.
Locate the short seam and use the hem ripper to carefully cut through each stitch without damaging the fabric.
Attach the elastic band to the end of a pencil with a piece of tape.
Insert the pencil tip into one end of the fabric tube.
As you push the pencil through, scrunch the fabric together until the tip comes out the other side.
Prepare your needle and thread by tying a knot at the end.
Insert the needle at the spot holding each end of the tube together.
Use the ladder stitch technique to sew each end of the tube back together.
Use this guide for assistance.
Tie a knot and use your finger to keep the knot close as close to the fabric as possible.
Repeat this process until the thread is secure.
9 farklı kişi bu kılavuzu tamamladı.
